Minimal successor set - difficult
  • MHB
  • Thread starter Andrei1
  • Tags
    Set
In summary, the conversation discusses proving the statement "for all x,y\in\omega,\ \ x\subset y\vee y\subset x" and outlines a plan for the proof. The conversation also mentions using induction, the set operations of union and successor sets, and the equivalence between subset and strict subset.
Andrei1
36
Prove that for all \(\displaystyle x,y\in\omega,\ \ x\subset y\vee y\subset x.\)
If I assume that the conclusion is false then I can prove that for some \(\displaystyle a\in x,\ b\in y\) we have \(\displaystyle a\notin b\) and \(\displaystyle b\notin a.\)
Also I am thinking that if assume the contrary then \(\displaystyle \omega\) minus \(\displaystyle \{x\}\) or minus \(\displaystyle \{y\}\) or both is a smaller successor set. Should I try to prove this?
I get stuck in trying to prove for sets from \(\displaystyle \omega\) the equivalence: \(\displaystyle a\subseteq b\wedge a\not=b\Leftrightarrow\exists c(a\cup c^+=b)\).
Here's the plan.
(1) Prove \(\displaystyle a\subset b^+\Rightarrow b\notin a\) by induction on \(\displaystyle a.\) Use also \(\displaystyle x=y\Rightarrow x^+=y^+.\)
(2) Prove \(\displaystyle a\subseteq b\Leftrightarrow a\subset b^+\). In proving (\(\displaystyle \Leftarrow\)) side use (1). In proving (\(\displaystyle \Rightarrow\)) side use \(\displaystyle x\subset x^+\), which follows from \(\displaystyle x\notin x.\)
(3) Prove \(\displaystyle b\subset a\Leftrightarrow b^+\subseteq a\). In proving (\(\displaystyle \Rightarrow\)) side use induction on \(\displaystyle a.\) Use also \(\displaystyle x=y\Rightarrow x^+=y^+\) and \(\displaystyle x\subseteq x^+.\) In (\(\displaystyle \Leftarrow\)) side you need \(\displaystyle x\notin x.\)
(4) Prove \(\displaystyle a\subset b\vee a=b\vee b\subset a\) by using (2) and (3). Use induction.
FAQ: Minimal successor set - difficult
What is a minimal successor set?
A minimal successor set is a set of objects or elements that are arranged in a specific order such that each element is the direct successor of the previous one. This means that there is no element in the set that comes before the first element or after the last element.
Why is finding a minimal successor set difficult?
Finding a minimal successor set can be difficult because it requires careful consideration and analysis of the elements in the set. There are often many possible arrangements of elements, and determining the most minimal and efficient order can be challenging.
What is the significance of a minimal successor set?
A minimal successor set is significant because it represents the most efficient way to arrange a set of objects or elements. It can also be used to solve various mathematical and computational problems, such as finding the shortest path between two points.
How is a minimal successor set calculated?
The calculation of a minimal successor set involves analyzing the elements in the set and determining the most efficient order based on a specific criterion. This can be done manually or using algorithms and mathematical techniques.
Can a minimal successor set be applied to real-world situations?
Yes, a minimal successor set can be applied to real-world situations, such as scheduling tasks, organizing data, and optimizing processes. It can also be used in various fields, including computer science, mathematics, and engineering.
