Minimal surface area for a fixed volume
In summary: Substitute ##2y## for ##x## in ##y^2 x = 120##.##y^2 * 2y = 120##.##2y^3 = 120####y^3 = 60##root(60)y = 3.912y = x3.91 x 2 =xx = 7.82z = 120/xyz = 120/(7.82)(3.91)z = 3.92s = 2yz + xz + xys = 2(3.91)(3.92) + (7.82)(3.92) + (
lee123456789
93
a hut has to side walls a roof and back wall. its front is open. its total volume is 120m^3 fdetermine the miniumal surface area necessary for a sheet to be put over it
Attempt 2
V=xyz=120 z=120/xy
s = 2yz + xz + xy
s = 2y(120/xy) + x(120/xy) + xy s = (240/x) + (120/y) + xy
s' = y - 240/x^2 = 0
S' = x - 120/y^2 = 0
(X^2)y = 240
(y^2)x = 120
(X^2)y/(y^2)x = 240/120 = 2
2= x/y
x=2y
x=2y
2y * (y^2) = 2y^3
2y^3 = 120
y = 3.91
x = 7.82
Z = 120/xy
Z = 120/(3.91)(7.82) = 3.92
Z = 3.92
s'' = 480/x^3 = 480/7.82^3 = 1
s'' = 240/y^3 = 240/3.91^3 = 4
(2^2) - (1)(4) = 0
(X^2)y/(y^2)x = 240/120 = 2 postive so is min
s = 2yz + xz + xy
2(3.91)(3.92) + (7.82)(3.92) + (3.91)(7.82) = 91.88m^3 surface area min
lee123456789 said:
s = 2yz + xz + xy s = 2y(120/xy) + x(120/xy) + xy s = (240/x) + (120/y) + xy
A comment on formatting. This was a little hard to read. I understand the urge to compress things into a single line when you have so many equations to enter, but I prefer to put an implication symbol ##\implies## or ##\iff## or ##\rightarrow## between equations when doing that, to make it more clear where one equation stops and the next begins.
Even without the LaTeX editor, you could use the convention -> for this purpose. But people here prefer you use LaTeX. See link to "LaTeX Guide" at lower left corner.
Thus: ##s = 2yz + xz + xy \implies s = 2y(120/xy) + x(120/xy) + xy \implies s = (240/x) + (120/y) + xy##
lee123456789 said:
s' = y - 240/x^2 = 0 S' = x - 120/y^2 = 0
I guess you mean these to be the partials with respect to ##x## and ##y## respectively. Again, not clear.
lee123456789 said:
x/y = 240/120 = 2
X=y
Oops. If x/y = 2 then x and y are not equal. You handled this equation correctly in "Attempt 2", which I will now skip to.
lee123456789 said:
x=2y 2yx(y^2) = y^4
Where did that second equation come from? Which equation are you substituting into?
lee123456789 said:
y^4 = 120
y = 3.30
x = 6.60
I get 3.31 as the 4-th root of 120. But I think there's something suspect in your algebra, as ##x^2y \neq 240## and ##y^2x \neq 120##. These are not the solutions to your system of equations.
Your approach seems mostly correct, I just think there are careless algebra errors in both attempts.
Thus: ##s = 2yz + xz + xy \implies s = 2y(120/xy) + x(120/xy) + xy \implies s = (240/x) + (120/y) + xy##I guess you mean these to be the partials with respect to ##x## and ##y## respectively. Again, not clear.
Oops. If x/y = 2 then x and y are not equal. You handled this equation correctly in "Attempt 2", which I will now skip to.Where did that second equation come from? Which equation are you substituting into?
it was made up of two overal equations
i got it from these
(X^2)y = 240
(y^2)x = 120
then if 0.5X = y
2y subbed into equation = y^4
thought it would be easier than using 1/2x in the x equation
what but do i have to look atr if u don't mind me asking
Please be more explicit in what you're doing.
##x^2 y = 240##.
Replace ##x## by ##2y##
##4y^2 * y = 240##
I'm not seeing where that becomes ##y^4 = 120##.
Please show your steps.
##x^2 y = 240##.
##4y^2 * y = 240##
x=2y
##y^2 x= 120##.
##y^2 * 2y = 120##.
##2y^3 = 120##
##y^3 = 60##
root(60)
y = 3.91
2y = x
3.91 x 2 =x
x = 7.82i got muddle with my powers
can i sub both 2y into the ##X^2 y = 240 ## or the other way round x into the ##y^2 x = 120##
Z = 120/xy
Z = 3.92
(2^2) - (1)(4) = 0
s = 2yz + xz + xy
I'm not sure what this means. It sounds like we are putting a sheet over the whole shed, which would make the fact that the front is open is irrelevant. But I suspect that you are right, that it intends just the surface area of roof and three walls.
lee123456789 said:
91.88m^3
You could get a bit more accuracy (your answer is not as accurate as you are effectively claiming) by keeping everything in an exact algebraic/rational form until the final step. I.e. from 2y3 = 120, just obtain that y=601/3 and leave it at that until you have combined the three dimensions back into the expression for total area and simplified.
FAQ: Minimal surface area for a fixed volume
What is the concept of minimal surface area for a fixed volume?
The concept of minimal surface area for a fixed volume refers to finding the shape or surface that has the smallest possible area while still containing a specific volume. This is often studied in mathematics and physics, as it has practical applications in fields such as architecture and materials science.
Why is minimal surface area for a fixed volume important?
Finding the minimal surface area for a fixed volume is important because it can help us understand and optimize the efficiency of various structures and materials. It also has real-world applications, such as in the design of packaging or the development of new materials with specific properties.
How is minimal surface area for a fixed volume calculated?
The calculation of minimal surface area for a fixed volume involves using mathematical principles, such as calculus and geometry, to determine the shape or surface with the smallest possible area. This can be done analytically or numerically using computer simulations.
What are some examples of minimal surface area for a fixed volume in nature?
Examples of minimal surface area for a fixed volume in nature include soap bubbles, which form a minimal surface due to the surface tension of the soap film, and the shape of a droplet of water, which is a minimal surface due to the cohesive forces between water molecules.
How does minimal surface area for a fixed volume relate to real-world applications?
The concept of minimal surface area for a fixed volume has many real-world applications, such as in the design of efficient building structures, the development of lightweight and strong materials, and the optimization of packaging for transportation and storage. It also has implications in the study of biological systems, such as the shape of cell membranes and the structure of proteins.
