Minimal value to be determined
  • Thread starter senmeis
  • Tags
    Value
In summary: But, it seems like we've wandered a bit off topic. Any more thoughts on the question at hand?This is true and something that I forget about from time to time. I seem to recall it also has the benefit that, symbolically, it (or ##LDL^T## ) can be done using exact arithmetic over rationals which in many cases means stronger / more... 'verifiable' results.But, it seems like we've wandered a bit off topic. Any more thoughts on the question at hand?In summary, the problem at hand involves finding an integer value of X that minimizes the quadratic form f = (A-X)TB(A-X), where A is a
senmeis
69
A and X: 6x1 vectors
A = [-0.39; -3.99; 1.01; 0.57; -0.70; -2.81]B: 6x6 symmetrical matrix
B = [1.1 -0.2 0.19 -1.03 0.69 -0.47
-0.2 0.17 -0.25 0.43 -0.06 -0.05
0.19 -0.25 0.88 -0.62 -0.21 0.29
-1.03 0.43 -0.62 1.59 -0.3 0.04
0.69 -0.06 -0.21 -0.3 0.97 -0.62
-0.47 -0.05 -0.29 0.04 -0.62 0.59]An integer X shall be determined so that f = (A - X)t•B•(A - X) is minimal.
I think the critical condition is X must be integer so the conventional method grad(f) = 0 cannot be applied.
Do you allow negative integers, or must all the elements of X be ##\geq 0## (or ##> 0##)?
Anyway, the problem appears to be unbounded: we can find a sequence of integer ##X > 0## that have ##(A-X)^T B (A-X) ## going to ##-\infty##.
However, that may be due to a typo in your matrix: if you change your ##b_{6,3}## to ##+0.29## everything is OK. The matrix you wrote is not symmetric.
Sorry, b6,3 is really +0.29.There are no limitations on elements in X, negative or positive.I think f cannot be negetive in any case. Maybe this statement can be proved with the characteristics that B is symmetric.Senmeis
With the corrected value ##b_{6,3} =0.29## the matrix ##B## is "positive-definite", which means that ##f(w) = w^T B w > 0## for any nonzero vector ##w##. So, of course, the minimum of ##f(a-x)## is 0, obtained at ##x = a = [-0.39; -3.99; 1.01; 0.57; -0.70; -2.81]##. I suspect (but cannot prove) that the best integer values of ##x## will be near those of ##a##, so (probably) ##x_1 = 0## (or maybe ##x_1 = -1##), ##x_2 = -4##, ##x_3 = 1##, ##x_4 = 1## (or maybe ##x_4 = 0##), ##x_5 = -1## and ##x_6 = -3##.
A type of "branch-and-bound" method could be used to get a provable integer solution, but it would be tedious and would require solutions of bound-constrained problems like ##\min_{\{x_1 \leq -1, x_4 \geq 1\}} f(a-x)## and ##\min_{\{x_1 \geq 0, x_4 \leq 0\}} f(a-x)##, etc.
For more on positive-definiteness, see
https://en.wikipedia.org/wiki/Positive-definite_matrix.
Likes StoneTemplePython
A couple thoughts:
1.) What course is this for? There are integer domain quadratic programming libraries out there that could be used (e.g. Gurobi but needs a license) though this is something of an exotic topic.
2.) I was a bit confused by this statement:
In general, for optimizing quadratic forms (unless there are special constraints like memory usage or you have linear / constant terms to deal with), you wouldn't typically first look at the gradient... the eigenvalue argument (assuming we're in Reals and matrix is / has been 'symmetrized' ) is the standard argument that one looks to, and allows one to make claims about positive definiteness as @Ray Vickson mentioned. This is intimately tied in with the multi variable second derivative test (i.e. evaluating the Hessian Matrix of a scalar valued function) so it's worth spending some time thinking on it.
StoneTemplePython said:
A couple thoughts:
Although most of the web pages devoted to "positive-definiteness" emphasize eigenvalue tests, etc., by far the easiest and efficient way to test a matrix is to compute its Cholesky decomposition. For an ##n \times n## matrix you get in ##O(n^2)## simple arithmetical steps the Cholesky factor, or else prove it does not exist, so that the matrix is indefinite (assuming you have looked at the diagonal elements and found them to all be > 0---so the matrix is not negative-definite!). I once wrote a routine for a programmable HP calculator that could test matrices up to about ##10 \times 10##.
This is true and something that I forget about from time to time. I seem to recall it also has the benefit that, symbolically, it (or ##LDL^T## ) can be done using exact arithmetic over rationals which in many cases means stronger / more exact claims than using numerical eigenvalue estimates.
I thought Cholesky was ##O(n^3)##, though, just with a very low coefficient? I suppose you're suggesting that there's an option of early stopping that is tucked in the weeds of the algorithm...
You're right: it is ##O(n^3)##.
I’ve guessed the answer the same way as you did, butX1 = [0, -4, 1, 1, -1, -3]
X2 = [0, -5, 1, 1, -1, -3]f(X2) < f(X1)so it’s not so straightforward as it looks.Senmeis
No, indeed: combinatorial optimization problems are often far from straightforward, and some of them can be downright nasty (NP-hard).
FAQ: Minimal value to be determined
What is the definition of "Minimal value to be determined"?
The minimal value to be determined refers to the smallest or lowest possible value that can be accurately measured or determined in a given experiment or observation. It is often used in scientific research to establish a baseline or starting point for further analysis.
Why is it important to determine the minimal value?
Determining the minimal value is important because it allows scientists to accurately measure and compare data. Without a known minimal value, the results of an experiment or observation may be skewed or inaccurate, leading to incorrect conclusions.
How can the minimal value be determined?
The minimal value can be determined through various methods, such as statistical analysis, trial and error, or calibration. It may also be based on the sensitivity of the measurement equipment or the precision of the experimental procedure.
Does the minimal value change for different experiments?
Yes, the minimal value can vary for different experiments and observations. It is dependent on the specific parameters and variables being measured, as well as the accuracy and precision of the equipment and techniques used.
What are some practical applications of determining the minimal value?
Determining the minimal value is important in a wide range of scientific fields, including medicine, environmental science, and engineering. It allows for accurate and precise measurements of data, which can lead to advancements in technology, understanding of natural processes, and development of new treatments and solutions.
