MHB Minimize Crease Length of Paper in Terms of Width
  • Thread starter Thread starter MarkFL
The discussion revolves around minimizing the crease length \( L \) created when a rectangular piece of paper with width \( W \) is folded. The crease length is expressed mathematically, with contributions highlighting that when the segment \( AB \) equals \( \frac{3W}{4} \), the relationship \( L^2 = \frac{2a^3}{2a - W} \) holds. Participants analyze the geometric properties of the resulting triangles formed during the fold, leading to a derived equation involving derivatives to find the minimum crease length. The conversation also touches on the rarity of integer solutions for the minimum crease length condition. The problem is acknowledged as complex yet engaging, showcasing the interplay of geometry and algebra in practical applications.
MarkFL
MHB
Hello MHB,
Consider a rectangular piece of paper of width $W$ laid on a flat surface. The lower left corner of the paper is bought over to the right edge of the paper, and the paper is smoothed flat creating a crease of length $L$, as in the diagram:
What is the minimal value of $L$ in terms of $W$?
Mathematics news on Phys.org
MarkFL said:
Hello MHB,
https://www.physicsforums.com/attachments/1078
...A...... B
When AB = 3W/4
a = AB
L^2 = (2a^3) / (2a - w)
Above is my contribution...(Coffee)
Wilmer said:
When AB = 3W/4
a = AB
This is correct...can you show how you arrived at this solution? (Sun)
Code:
A                       F
                        D
C                 B     E
a = BC = BD, b = AC = AD, c = AB, w = AF
Mark, that's a frustratingly delightful li'l problem!
Boils down to 2 congruent right triangles (ABC and ABD)
stuck together along the common hypotenuse AB, then
"completing the rectangle" (ACEF) thus forming
2 similar right triangles (ADF and BDE).
Simple enough it appears, but I'm kinda stuck.
I've been able to "see" that when c (your L) is at minimum,
then b = aSQRT(2) and c = aSQRT(3); so c = 3wSQRT(3) / 4,
using my previous observation: a = (3/4)w.
So I need to come up with some equation such that after
taking its 1st derivative, I'm left with 4c = 3wSQRT(3).
Can't wrap it up; take me out of my misery!
Wilmer said:
...Can't wrap it up; take me out of my misery!
Okay, here is my solution:
I have filled in the previous diagram with the information I need:
By similarity, we may state:
$$\frac{\sqrt{L^2-x^2}}{W}=\frac{x}{\sqrt{W(2x-W)}}$$
Squaring, we obtain:
$$\frac{L^2-x^2}{W^2}=\frac{x^2}{W(2x-W)}$$
$$L^2-x^2=\frac{Wx^2}{2x-W}$$
$$L^2=\frac{2x^3}{2x-W}$$
At this point we see that we require $$\frac{W}{2}<x\le W$$.
Minimizing $L^2$ will also minimize $L$, and so differentiating with respect to $x$ and equating to zero, we find:
$$\frac{d}{dx}\left(L^2 \right)=\frac{(2x-W)\left(6x^2 \right)-(2)\left(2x^3 \right)}{(2x-W)^2}=\frac{2x^2(4x-3W)}{(2x-W)^2}=0$$
Discarding the root outside of the meaningful domain, we are left with:
$$4x-3W=0$$
$$x=\frac{3}{4}W$$
The first derivative test easily shows that this is a minimum, as the linear factor in the numerator, the only factor which changes sign, goes from negative to positive across this critical value.
Thus, we may state:
$$L_{\min}=L\left(\frac{3}{4}W \right)=\sqrt{\frac{2\left(\frac{3}{4}W \right)^3}{2\left(\frac{3}{4}W \right)-W}}=\frac{3\sqrt{3}}{4}W$$
Thanks Mark.
Somewhat tougher than I thought...
Sure glad to see the SQRT(3)!
Damn! I was ok up to your L^2 = 2x^3 / (2x - W) , then to 2x^2(4x - 3W) = 0
Entirely forgot about this:
"Discarding the root outside of the meaningful domain, we are left with:"
Gotta good memory, but it's short (Emo)
(I don't have enough hair to do that!)
Again, NICE problem.
Of course, there will be no "all integer" solutions.
Interestingly, very few exist if "minimum L" condition is removed;
only 4 primitives keeping short leg of right triangle < 10000:
(right triangle sides, W):
75,100, 125, 96
845, 2028, 2197, 1440
2312, 4335, 4913, 3600
4375, 15000, 15625, 8064
