Minimizing Positive Terms in a Sequence with Alternating Signs
  • MHB
  • Thread starter Albert1
In summary, to find the least number of "$+$" triangles that can be used to make A=1 in the sequence $1\triangle2\triangle3---------\triangle2008\triangle2009=1$, where $\triangle$ can only be replaced by either "$+$" or "$-$", we follow the steps of finding the sum of all the numbers from $1$ to $n$ and setting up a quadratic equation. Solving for $r$, we get the value $r = \tfrac12\bigl(2n+1 - \sqrt{2n^2 + 2n + 1}\bigr)$, which for $n=2009$ gives us $r = 588
Albert1
1,221
A=$1\triangle2\triangle3---------\triangle2008\triangle2009=1$
where $\triangle$ can be replaced only by eather "$+$" or "$-$" , find the least number of "$+$" can be ued to make A=1
Mathematics news on Phys.org
where $\triangle$ can be replaced only by either "$+$" or "$-$" , find the least number of "$+$" can be used to make A=1
[sp]For the whole sum to be equal to $1$, the sum of the positive terms must be almost the same as the sum of the negative terms. In order to minimise the number of positive terms, it seems clear that we should take the positive terms to be as large as possible (so that there will be fewest of them).
Writing $n$ for $2009$, the sum of all the numbers from $1$ to $n$ is $\frac12n(n+1).$ Suppose that there is a number $r < n$ such that the sum of the $r$ largest numbers in the sequence (namely the numbers $n-r+1$ to $n$ inclusive) is exactly half of the total. The condition for that is $$rn - \tfrac12r(r-1) = \tfrac14n(n+1).$$ Solve that quadratic equation for $r$ to get $$r = \tfrac12\bigl(2n+1 - \sqrt{2n^2 + 2n + 1}\bigr)$$ (taking the negative sign for the square root to ensure that $r<n$). Plugging in the value $n=2009$, I get $r = 588.56...$.
So it looks as though we should take the $588$ largest numbers on the sequence (namely $1422$ to $2009$ inclusive) to have positive signs, and then to have just one further positive term to make the sum of the positive terms $1$ more than the sum of the remaining (negative) terms.
In fact, the sum of all the numbers from $1$ to $2009$ is $2019045$. Half of that is $1009522.5$. So we want the sum of the positive numbers in the sequence to be $1009523$, and the sum of the negative numbers in the sequence to be $1009522.$ The first term in the sum (namely $1$) has no $\triangle$ in front of it, so must necessarily be positive. The sum of the numbers $1422$ to $2009$ is $1008714$, leaving a shortfall of $1009523 - 1008715 = 808$ for the sum of the positive terms.
Thus the minimal number of positive terms is given by taking the numbers $808$, and $1422$ to $2009$ inclusive, to be preceded by $\triangle = +$, and all the remaining triangles to be $\triangle = -.$ That gives the minimal number of "$+$" triangles to be $589.$[/sp]
very good !
FAQ: Minimizing Positive Terms in a Sequence with Alternating Signs
What is the definition of "the least number of"?
The least number of refers to the smallest or minimum amount of something.
How is the least number of calculated in mathematics?
In mathematics, the least number of can be calculated by finding the smallest value in a set of numbers or by using the concept of absolute value.
What is the significance of finding the least number of in a data set?
Finding the least number of in a data set can provide important information about the range and distribution of the data. It can also be used to identify outliers or anomalies in the data.
Can the least number of change?
Yes, the least number of can change depending on the data being examined. It is not a fixed value and can vary depending on the context.
How is the concept of the least number of used in real-world applications?
The concept of the least number of is used in various fields such as economics, statistics, and computer science to analyze and make decisions based on data. For example, in supply chain management, finding the least number of can help determine the most cost-effective way to produce and distribute goods.
