Minimum bending radius for a tube
In summary, calculating the minimum bend radius for a tube involves following a standard of 4 times the outer diameter. However, there may be a more accurate relationship to consider, including wall thickness. If an elbow fitting cannot be used, there are alternatives such as weld fittings or a mitre joint, though this is not recommended. The tube in question is a 7/32 inch outer diameter, and attempts to bend to a .41 inch diameter curve have been unsuccessful. Suggestions include using a mandrel, packing sand or low-temperature solder in the tube, or considering plastic material. Burst testing may be necessary to ensure strength after forming. Machining or casting the bend and welding it to the rest of the tube may also be an option
xJuggleboy
How do you calculate the minimum bend radious for a tube?
Its a SS tube and we want to bend as small a radius as possible...
The standard I always follow is 4 times the OD. I'll see if I can't dig up a relationship that is a bit more accurate to include wall thickness.
BTW...what size tube? Is there any reason you can't use a 90° fitting?
I have 3 Swagelok tube benders under my desk. The 1/4" and 1/2" are both the standard 3:1 radius, and the 3/8" is a standard also with a bend radius of just a bit more than 3:1. I believe the Parker ones are the same.
If you can't use an elbow as Fred suggests, there are weld fittings, or you might even consider making it a mitre joint, though that's very uncommon and generally not good practice.
The Tube is a 7/32 OD I am not sure of the Wall thickness but the bend we need to make is about a .41 diamiter curve and it has to go 180Deg.
Bassiacly a U shape. the .41 is the id of the U.
But so far what I hear is the bend is way to small for the tube :cry:
Why not just make up a mandrel and try it? You don't have much to loose. I'd be a bit concerned about hoop stress because when you bend a tube, the ID will thicken but the OD will thin. If you're trying to meet a piping code, and especially if this is a mass produced item, it would be wise to apply minimum wall thickness to the thinned OD of the tube. That said, what pressure are you going to, what material is the tube made from and what are you flowing through it?
Questions:
First of all...7/32? Couldn't you make this easy and make the tube Ø.250?
What's the set up like? Where is this tube going? If you can give us a general idea of what the plumbing is doing we may be able to find an alternate method.
FredGarvin said:
we may bea ble to find an alternate method.
If it's a low-pressure, non-reactive environment, plastic might be easier to use... but it seems unlikely if the first choice was stainless.
What about taking a look at the Crane paper?? :smile: :smile: :smile:
Hardee-har-har. Go back to your tube now.
Well to answer some of the questions...
The size and material of the tubs can not be changed... Its for high pressure hydrogen.
I have been trying it. I made a few mandrels and the tube always kinks. Even with Annelling it.
Im pritty positive it can't be bent as tight as I am trying... I still have a few more things to try.
Now I am trying to fill teh tube with a low temp solder before I bend it. Ill see how that works out...
LOL Maybe we need to perform an FEA analysis on it . . . <not>
I've also heard of people packing sand inside. That might be a bit more practical. But if this is for high pressure hydrogen, I'd suggest doing some burst testing (hydrostatic) to ensure you still have the proper strength after forming. Are you familiar with ASME B31.3? I'd assume that was the right code if you're in the US. There are some others depending on what kind of system it is. If you're in Europe, they have an equivalent code for pressure rating.
I tryed sand first... It didnt turn out so well...
And as far as coad goes... We make up our own coad! We don't need no stinking ASME! =-P
I think you may be stuck having to use some fittings and doing a little rerouting. You could possibly use a small manifold...
I keep trying to tell the head engener that
I have no idea what strength issues this will insult, but what about either machining or casting the bend and then welding it to the rest of the tube?
That would be a nice thing... But time and money won't allow for that =-(
I would like to thank you all for your input :smile: I think we have come up with a solution. We are filling the tube with a low tep solder then bending it to a slightly larger diamiter. It seems to be working! :approve:
Please keep us posted regarding your progress. Happy hunting.
Well after my 2 week vacation... I decided that the best thing to do was bending the tube after filling it with solder.
The bends came out pritty good. It is just a pain in the ass to make. and I need to make a bunch of them. Thanks fer the help everyone! =-)
Hopefully you can get a small assembly line set up to ease the pain a bit. Glad it's working out.
FAQ: Minimum bending radius for a tube
What is the minimum bending radius for a tube?
The minimum bending radius for a tube is the smallest radius at which a tube can be bent without causing structural damage or deformation.
How is the minimum bending radius determined for a specific tube?
The minimum bending radius for a tube is determined by several factors, including the material and thickness of the tube, the type of bending process, and the intended use of the tube.
What happens if a tube is bent below its minimum bending radius?
If a tube is bent below its minimum bending radius, it may experience cracking, buckling, or other forms of permanent damage that can weaken the structural integrity of the tube.
Can the minimum bending radius be changed or adjusted for a tube?
The minimum bending radius for a tube is typically determined by the physical properties of the material and cannot be easily changed or adjusted. However, certain specialized bending processes may allow for tighter or more flexible bending radii.
How does the minimum bending radius affect the performance of a tube?
The minimum bending radius can significantly impact the performance of a tube, as it can affect factors such as flow rate, pressure capacity, and structural strength. It is important to follow the recommended minimum bending radius to ensure optimal performance and longevity of the tube.
