juantheron
- 247
- 1
If p(x) is a polynomial such that p(0)=5 ,p(1)=4 ,p(2)=9,p(3)=20 ,
the minimum degree it can have
jacks said:If p(x) is a polynomial such that p(0)=5 ,p(1)=4 ,p(2)=9,p(3)=20 ,
If [tex]p(x)[/tex] is a polynomial such that: .[tex]p(0) = 5,\;p(1) = 4,\;p(2) = 9,\;p(3) = 20,[/tex]
. . the minimum degree it can have is __.
Then polynomial, passing through four given points, will have degree at most three, not "at least". It is quite possible that the four points happen to lie on a parabola (which is apparently the case here) or even on a straight line.Prove It said:You have four points, so for them to fit the polynomial exactly, you need it to at least have degree three. Anything more you'll have an infinite number of possibilities that will have all data points fit, and anything less then chances are you'll only be able to get a least squares approximation.
HallsofIvy said:Then polynomial, passing through four given points, will have degree at most three, not "at least". It is quite possible that the four points happen to lie on a parabola (which is apparently the case here) or even on a straight line.
Prove It said:Really? I would have thought that there would be an infinite number of solutions to, say, four equations in five unknowns, which is what you would get if you substituted the four points into a general polynomial of degree 4...
The minimum degree of a polynomial that can pass through a set of points is equal to the number of points minus one. This is known as the "degree of exactness" and is based on the fundamental theorem of algebra.
To determine the minimum degree of a polynomial passing through points, you need to first plot the points on a graph. Then, you can use the formula (n-1) where n is the number of points, to find the minimum degree. Alternatively, you can also use linear algebra techniques to solve for the coefficients of the polynomial.
No, a polynomial with a degree lower than the minimum degree cannot pass through the points. The minimum degree is the lowest possible degree that can pass through the given points exactly. A polynomial with a lower degree will not have enough flexibility to pass through all the points.
If there are more points than the minimum degree of the polynomial, then the polynomial may not pass through all of the points exactly. It will try to approximate the points as closely as possible, but there may be some error. In this case, a higher degree polynomial may be required to pass through all of the points exactly.
Yes, it is possible for a polynomial with a degree higher than the minimum degree to pass through the points. This polynomial will have more flexibility and may provide a better fit to the data points. However, it is not necessary to use a polynomial with a higher degree if the minimum degree is sufficient to pass through the points exactly.
