MHB Minimum Degree of a Random Graph (Probabilistic Method)
The discussion focuses on proving that in a random graph $G(n, p)$ with a probability function $p$ satisfying $p >> n^{-1} \ln(n)$, the minimum degree is at least $\frac{np}{2}$ almost surely as $n$ approaches infinity. The approach involves analyzing the degree of a fixed vertex using Chernoff's Inequality, where the degree is represented as a sum of independent indicator variables for edges. It is shown that the probability of a vertex having a degree less than $\frac{np}{2}$ decreases exponentially, leading to the conclusion that all vertices must have a degree of at least $\frac{np}{2}$. Consequently, it is established that for any fixed positive integer $k$, the minimum degree of the random graph is at least $k$ almost surely as $n$ increases. This conclusion is supported by the earlier findings in part (a).
joypav
Problem:
Suppose that the function $p : N \rightarrow [0, 1]$ satisfies $p >> n^{-1}ln(n)$ (i.e. $n^{-1}ln(n) = o(p)$).
(a) Prove that as $n \rightarrow \infty$, the random graph $G(n, p)$ has minimum degree at least $\frac{np}{2}$ almost surely.
Idea: Look at the degree of each individual vertex $v \in V(G)$. Try to find a bound on the probability of this fixed vertex having a small degree (using Chernoff's Inequality?).
I am not getting to where I think I should with this idea.
Let $X_{u,v}$ be $1$ is $uv \in E(G)$ and $0$ if $uv \notin E(G)$.
Then, $X_v = \sum_{u \in V(G), u \neq v} X_{u,v}$ will give us the degree of $v$.
Also, the $X_{u,v}$'s are uniform/independent (as $G$ is a random graph and edges are picked independently with probability $p$).
Now we may use Chernoff's? How do I use the first thing we assumed... that $p >> n^-1ln(n)$?
(b)
Conclude that for any fixed positive integer k, the random graph $G(n, p)$ has minimum
degree at least k almost surely as $n \rightarrow \infty$.
For completeness, I will post a "proof" I came up with. As you can see, at the end I skipped over some much needed justification that I couldn't seem to figure out. Some help with this would be appreciated!
However, I do think that my general idea is correct.
Proof: (a) Let $G \sim G(n,p)$. Fix $v \in V(G)$. Let $A_{v,u}$ be the event that $vu \in E(G)$ and let $X_{v,u}$ be its indicator. Then, $X_{v,u}=1$ with probability $p$ and $X_{v,u}=0$ with probability $1-p$. Because each possible edge is inserted independently, the $X_{v,u}$'s are independent. Let $X_v = \sum_{u \in V(G), u \neq v} X_{u,v}$, (giving the degree of $v$). Now we may use Chernoff's Inequality with:
$$\sigma^2 = Var[X_v] = np(1-p)$$
$$E[X_v] = \sum_{u \in V(G), u \neq v} E[X_{u,v}]=p(n-1)$$
Then,
$P[$degree of v is less than $\frac{np}{2}] = P[X_v \leq E[X_v] - \frac{np-2p}{2}] = P[X_v \leq \frac{np}{2}]$
$$ \leq e^{\frac{-(\frac{np-2p}{2})^2}{2(np+\frac{\frac{np-2p}{2}}{3})}} = e^{-\frac{3n^2p-12np+12}{28n-8}}$$
Let $X$: existence of vertices with degree less than $\frac{np}{2}$. Then,
$$P[X]= \sum_{v \in V(G)}P[X_v \leq \frac{np}{2}] \leq n\cdot e^{-\frac{3n^2p-12np+12}{28n-8}} = e^{ln(n)-\frac{3n^2p-12np+12}{28n-8}}$$
By assumption $p > > n^{-1}ln(n)$.
$$\Rightarrow ln(n)-\frac{3n^2p-12np+12}{28n-8} \rightarrow -\infty $$
$$\Rightarrow P[X]\rightarrow 0$$
Then every vertex of G must have degree at least $\frac{np}{2}$.
(b) Apply part (a). So we have $\delta(G) \geq \frac{np}{2}$ a.s. as $n \rightarrow \infty$. As long as $n \geq \frac{2k}{p}$, $\delta(G) \geq k$.
First trick I learned this one a long time ago and have used it to entertain and amuse young kids. Ask your friend to write down a three-digit number without showing it to you. Then ask him or her to rearrange the digits to form a new three-digit number. After that, write whichever is the larger number above the other number, and then subtract the smaller from the larger, making sure that you don't see any of the numbers. Then ask the young "victim" to tell you any two of the digits of the...
