Minimum or Maximum value of a multivariate function
In summary, Lagrange multipliers can be used to incorporate the constraint that the sum of a set of n independent quadratic functions be a given value.
jkim8512
Not a hw
First thank you for taking your time to take a look at this simple question. And sorry for the informal math language and equations, I hope you guys can understand it.
So, depending on the case, I have 2 or 8 simple quadratic functions f(a), f(b), f(c),… f(z).
Each a,b,c,…,z have a different range for f(a),f(b), f(c), .. ,f(z). These functions are all independent to each other, they are just simple quadratic functions.
These functions adds up to get one value f(T).
The constraint is that the sum of a,b,c,…,z should be a given value N.
And what I want is the Minimum or maximum value of f(T)So, If I right it down in some simple math, it looks like this.
f(T) = f(a) + f(b) + f(c) + f(d)+….+f(z)
constraint: N = a+b+c+d+….+z
goal: Find minimum or maximum value of f(T) when N is given.
where,
f(a) = simple quadratic function such as 3a^2+ 4a+ 5, range: a_start < a < a_end
f(b) = simple quadratic function such as 3b^2+ 4b+ 5, range: b_start < b < b_end
f(c) = simple quadratic function such as 3c^2+ 4c+ 5, , range: c_start < c < c_end
………… same up to f(z)
I googled some stuff and found I could probably use “Max/min for functions of multi variables” things like that.
The main problem I can’t figure out is how to deal with the constraints I need to have regarding N=a+b+c,..+z
Thanks again!
Likes Delta2
Your notation is pretty bad, it would be a lot clearer if your wrote ##f(x_1,...,x_n) = f_1(x_1)+...+f_n(x_n)##.
The thing you need to use to incorporate the constraint is lagrange multipliers.
https://en.m.wikipedia.org/wiki/Lagrange_multiplier
Basically the idea is that gradient of the function you are minimizing has to be parallel to the gradient of the constraint.
Likes Delta2 and jkim8512
Thank you so much. It seems like the right thing to look at.
Likes berkeman
You can have a look at the LaTeX Guide link in the lower left of the Edit window to see how to best post math equations online... :smile:
Likes jkim8512
First thank you all for the kind reply.
I took a look into Lagrange multipliers. It seems like what I need to use.
However I still have one question. I am not sure about how to limit the range for x1,x2, x3, … ,xN
I want to find
Max/min of: f(x1,x2,…,xn) = f1(x1) + f2(x2) +... +fn(xn)
Constraint: x1+x2 +...+xn =N
X1 range: x1_start < x1 <x1_end
X2 range: x2_start < x1 <x2_end
X3 range: xn_start < xn <xn_end
I googled how to use the contraint by using the Lagrange multipliers. And I think i can do it.
But, I still don’t know what to do with the ranges for x1, x2, ... ,xn. Can you guys give me any hint for it or tell me what i have to look into?
Thanks!
Have a wonderful weekend!
You are trying to extremize [tex]
f(x_1, \dots, x_n) = \sum_{i=1}^n f_i(x_i)[/tex] subject to [itex]x_1 + \dots + x_n = N[/itex] and [itex]m_i \leq x_i \leq M_i[/itex] for [itex]i = 1, \dots, n[/itex]. The equality constraint can be enforced by using a lagrange multiplier and extremizing instead the function [tex]
F(x_1, \dots, x_n, \lambda) = f(x_1, \dots, x_n) + \lambda\left(\sum_{i=1}^N x_i - N\right).[/tex] It looks like an Interior point method might work to maximize [itex]F[/itex], since that will also enforce contraints of the form [tex]c_{2i-1}(x_1, \dots, x_n,\lambda) = x_i - m_i \geq 0[/tex] and [tex]c_{2i}(x_1, \dots, x_n, \lambda) = M_i - x_i \geq 0,[/tex] ensuring that the extrema are in the acceptable range of [itex]x_i[/itex].
Related to Minimum or Maximum value of a multivariate function
1. What is the definition of a multivariate function?
A multivariate function is a mathematical function that takes multiple variables as inputs and produces a single output. It can be written in the form f(x1, x2, ..., xn) = y, where x1, x2, ..., xn are the input variables and y is the output.
2. How is the minimum or maximum value of a multivariate function determined?
The minimum or maximum value of a multivariate function can be determined by taking the partial derivatives of the function with respect to each input variable, setting them equal to 0, and solving for the values of the variables. These values correspond to the critical points of the function, and the minimum or maximum value can be found by evaluating the function at these points.
3. Can a multivariate function have more than one minimum or maximum value?
Yes, a multivariate function can have multiple minimum or maximum values. These are known as local minimum or maximum values, and they occur at different points on the function's graph. The absolute minimum or maximum value of a multivariate function is the lowest or highest value on the entire graph.
4. What is the significance of the minimum or maximum value of a multivariate function?
The minimum or maximum value of a multivariate function can provide important information about the behavior of the function. It can indicate the most extreme points on the graph, as well as the points where the function changes direction. It can also be used to optimize the function for a given set of inputs.
5. How is the minimum or maximum value of a multivariate function affected by constraints?
If a multivariate function is subject to constraints, such as a limited range of input values, the minimum or maximum value may change. The constraints can restrict the possible values of the input variables, which can in turn affect the critical points and the overall shape of the function. In some cases, the minimum or maximum value may be located at a point that satisfies the constraints.
