Minimum wavelength when electrons strike phospor
In summary, the conversation discusses the problem of finding the minimum wavelength produced when electrons are accelerated through a potential difference of 20000 V inside a TV picture tube. The person uses the equation W=qV to find the speed, then plugs it into the de Broglie formula to find the wavelength. However, they realize that this gives the wavelength of the electron, not the photon it produces. They then use the equation E/c = h/λ to find the wavelength of the photon, which is the minimum wavelength that could be produced. The conversation ends with the person thanking kuruman for their help.
songoku
2,368
349
Assume electrons are accelerated through a potential difference of 20000 V inside a TV picture tube. What is the minimum wavelength that could be produced when the electrons strike the phosphor?
W = qV
I use the equation above to find the speed, then plug it in de Broglie formula to find the wavelength but there is no such answer in the multiple choices...Maybe we need to know the work function of phospor?
Thanks
To get help, please show your work and the possible answers. Otherwise, we can't tell what you did wrong, if anything.
Hi kuruman
Possible answers :
a. 0.62 angstrom
b. 1.15 angstrom
c. 10.5 angstrom
d. 100.9 angstrom
My work :
[tex]W=qV[/tex]
[tex]\frac{1}{2}mv^2=qV[/tex]
[tex]v=8386276.94~ms^-1[/tex]
Then
[tex]\lambda = \frac{h}{mv}[/tex]
[tex]=8.68\times 10^-12[/tex]
[tex]=0.087~\text{angstrom}[/tex]
What you calculated here is the wavelength of a 20 keV electron, not the photon that it produces. What is the relation between energy and wavelength for a photon? You can use the de Broglie expression, but momentum is not mv for a photon. What is it?
Hi kuruman
Momentum for a photon = E/c , where E = hf
Then, the equation will be :
[tex]p=\frac{E}{c}=\frac{hf}{c}=\frac{h}{\lambda}[/tex]
[tex]\lambda = \frac{h}{p}[/tex]
I don't know how to find the momentum...
Thanks
You don't really need the momentum. You know that the energy of the photon is 20 keV and you are looking for its wavelength. You already have the expression
E/c = h/λ
so go for it.
Hi kuruman
Oh now I get it. Thanks a lot ! :smile:
FAQ: Minimum wavelength when electrons strike phospor
What is the minimum wavelength for electrons to strike phosphor?
The minimum wavelength for electrons to strike phosphor is determined by the energy of the electrons. The shorter the wavelength, the higher the energy of the electrons. The minimum wavelength is typically in the range of nanometers, depending on the specific phosphor material.
How is the minimum wavelength calculated?
The minimum wavelength is calculated using the de Broglie equation, which relates the wavelength of a particle to its momentum. This equation is λ = h/mv, where λ is the wavelength, h is Planck's constant, m is the mass of the particle, and v is its velocity.
Why is the minimum wavelength important in electron-impact phosphor displays?
The minimum wavelength is important because it determines the resolution and sharpness of the image produced by the phosphor display. A shorter wavelength results in a higher resolution image, while a longer wavelength can lead to blurriness and reduced image quality.
Can the minimum wavelength be adjusted in electron-impact phosphor displays?
Yes, the minimum wavelength can be adjusted by changing the energy of the electrons. This can be done by adjusting the voltage applied to the electron gun in the display. Higher voltages result in higher energy electrons and shorter wavelengths.
How does the minimum wavelength affect the color of the display?
The minimum wavelength does not directly affect the color of the display. However, it can indirectly impact color by influencing the resolution and sharpness of the image. A higher resolution image can result in more accurate and vibrant colors. Additionally, different phosphor materials have different minimum wavelengths, so the choice of phosphor can also affect the color of the display.
