Mirror symmetry in String Theory?
In summary, according to the Wikipedia entry on string theory, string theory is a theory that encompasses the behavior of particles that have mass. It is found that any given physical model implies two Calabi-Yau spaces. The right-handed sector of matter might be the dark matter.
johne1618
371
From looking at the Wikipedia entry on string theory I gather that it is found that any given physical model implies two Calabi-Yau spaces.
Perhaps one space gives rise to a sector of particles with left-handed weak interactions and the other gives rise to a sector with right-handed weak interactions.
The right-handed sector might be the dark matter.
http://en.wikipedia.org/wiki/String_theory#Mirror_symmetry
Mirror symmetry in string theory is a type of duality, which is an equivalence between two theories. This type of duality means that the string theory on the CY manifold X is equivalent to another string theory on the mirror manifold Y. One does not add the matter computed from the theory on X to that computed from Y.
Instead, we note that the string theory on X has certain parameters, including the string coupling, as well as the size and shape parameters associated with X. For a certain range of parameters, the string theory on X is weakly-coupled and well-behaved. For other ranges, the string theory on X could be strongly coupled or otherwise poorly behaved. For instance when X develops a singularity, there are new light states appearing that are not easily described by the perturbative CFT description of X. For certain types of singularities, the description via the perturbative theory on Y is a better way to describe the physics.
Also the "mirror" term in mirror symmetry does not refer to spacetime parity. To understand it, one really needs to know some differential topology. But suffice to say, there is a certain type of topological data about manifolds, known as Hodge numbers. For a Calabi-Yau 3-manifold, the only Hodge numbers that can be different from 0 or 1 are ##h^{1,1}## and ##h^{1,2}## (while ##h^{2,1} = h^{1,2}##). When physicists plotted ##h^{1,1}## vs ##h^{1,2}## for the then known CY manifolds, they found a symmetry around the line ##h^{1,1}=h^{1,2}##. Namely, when there was a CY with Hodge numbers ##(h^{1,1},h^{1,2})=(a,b)##, there was a corresponding CY with numbers ##(h^{1,1},h^{1,2})=(b,a)##. These are the mirror pairs, and the mirror symmetry refers to the mirror reflection in the ##h^{1,1},h^{1,2}## plane when we plot the Hodge numbers of all CY 3-manifolds.
Thanks for the reply.
Related to Mirror symmetry in String Theory?
What is mirror symmetry in String Theory?
Mirror symmetry is a mathematical concept in string theory which states that there are two different ways to describe the same physical phenomenon. This means that a theory can look completely different in one representation, but still be equivalent to another theory.
Why is mirror symmetry important in String Theory?
Mirror symmetry is important in string theory because it allows us to study and understand theories that would otherwise be too complex to analyze. It also provides a way to relate different types of theories and gain insights into their properties.
How is mirror symmetry tested in String Theory?
Mirror symmetry is tested by comparing the predictions made by two different theories that are supposed to be mirror symmetric. If the predictions match, then it provides evidence for the existence of mirror symmetry.
What are the implications of mirror symmetry for our understanding of the universe?
Mirror symmetry has several implications for our understanding of the universe. It provides a new way to think about physical theories and their connections. It also opens up the possibility of using techniques from one theory to solve problems in another theory, leading to potential breakthroughs in our understanding of the universe.
Are there any limitations to mirror symmetry in String Theory?
While mirror symmetry is a powerful concept in string theory, it does have some limitations. It only applies to certain types of theories and may not hold in all situations. Additionally, the mathematics involved in mirror symmetry can be quite complex, making it challenging to apply in some cases.
  • Beyond the Standard Models
