Hak
- 709
- 56
- Homework Statement
- A mirror system consists of two perfectly reflecting half-planes arranged to form an angle of 45°. Let two points, A and B, be given within the angle formed by the two mirrors. Prove that regardless of their position, there are no optical trajectories from A to B with more than 4 reflections.
- Relevant Equations
I tried solving it in this way, distinguishing 3 cases and passing the first ray through the point located at a greater distance from the vertex of the angle formed by the two mirrors:
1) the angle of incidence of the ray on the mirror inclined 45° to the horizontal is 45° or 0°: in the first case the ray is parallel to the mirror placed on the horizontal, reflects perpendicular to it, then returns back following the same initial path; in the second case, after the second reflection the ray reflects parallel to the inclined mirror
2) the angle of incidence is greater than 45°: after the fourth reflection the ray begins to diverge from the inclined mirror.
3) the angle of incidence is less than 45°: after the third reflection the ray begins to diverge with respect to the mirror placed on the horizontal.
This is a purely intuitive demonstration, however, I should explain why the ray diverges. Perhaps because in case 2) after the fourth reflection the angles that the rays form with the horizontal are less than 45°. In case 3), on the other hand, the rays after the third reflection form angles greater than 45° with respect to the normal to the inclined mirror.
I do not see a quick and clean way to prove this. Do you have any hints?
