Mistake with Biot Savart, B of a circular loop integral
In summary, the conversation discusses two methods of solving for the magnetic field of a circular loop with a steady current. The first method uses the Biot-Savart Law and involves using "cute math" tricks, while the second method involves using cylindrical coordinates. The conversation also explores why the two methods may give different results and discusses the challenges of working with cylindrical coordinates. Ultimately, the conversation concludes that both methods should ultimately give the same result.
egoot247
I hope you don't mind if I'm a little liberal in your cute format.
I'm looking for why method 1 does not equal method 2.
1. Homework Statement : Method 1--the "cute math" method.
Alright, so...
I have a circular loop of radius A, let's place it in the xy plane, with a steady current I going counterclockwise as one looks down on it from the z axis (so I can have my B-field going upwards on the z axis). It is centered on the z axis.
I want to find the B-field of the loop anywhere on the z-axis.
I know how to solve this by simple fact that the integral of dl will be 2*∏*A:
The Biot-Savart Law is:
B(z)= μ0*I/4∏ ∫dl` x (R)/|R|3
Now, I know this is true-- basically in class we took the unit vector and "un-unitized it." So we have the full vector in the numerator and divided it by the magnitude of the vector, so although you see a cubed in the denominator, it's still an inverse square relationship.
The magnitude of R is √(A^2+z^2), and the non-z components of the magnetic field will cancel out, leaving us with a vector in the z-direction only, so
B(z)= μ0*I/4∏ ∫dl`x A/(A2+R2)(3/2)
Taking the integral of dl around my circle, this is obviously the circumference of the circle,
so
B(z)= μ0*I/4∏ 2*pi*A^2/(A2+R2)^(3/2)
And this is correct.
B(z)= μ0*I/2*A^2/(A2+R2)^(3/2)3. The Attempt at a Solution without using cute math.
My teacher once commented in reference to one of our homework problems that his only complaint about Griffifth's book is that it uses too many cute tricks, and expects us to adapt.
The homework problem in question is one that was easier to just "use the biot savart law, and let it all fall into place."
We all tried to use a cute trick from the example problem in the book.
So, I've been trying to do this problem from a different approach, and I get a wrong answer. Why?
B(z)= μ0*I/4∏ ∫dl` x (r-r`)/|r-r`|3
r will be the distance from the origin to the place on the z axis where I'm measuring the B-field. r` will be the distance to the ring at the dl`. dl` will be an infinitessimal part of the ring.
I think I want to work in cylindrical coordinates.
So
r= z *uz
r`=A *ur
B(z)= μ0*I/4∏ ∫dl` x (z*uz-A*ur)/(z^2+A^2)3
dl` I think should be A*dθ uθ. I believe this. I see it.
B(z)= μ0*I/4∏ ∫ A*dθ uθ x (z*uz-A*ur)/(z^2+A^2)3/2
And the integral is from 0 to 2 pi.
This gives me:
B(z)= μ0*I/2 [A*uθ x (z*uz-A*ur)/(z^2+A^2)3/2
B(z)= μ0*I/2 A^2 /(z^2+A^2)3/2 uz
But if you look closely, my r component didn't go away... :S I actually have a component along ur when I took the cross-product:
B(z)= μ0*I/2 A*z /(z^2+A^2)3/2 uR.
What do I do to get rid of that? What did I do wrong in my math? was there supposed to be a cosine or sine there somehow? But I can't mathematically justify sticking one in there...
What's wrong with this picture?
What is "cute" about using Biot-Savart? especially since it's the only way to do it, far as I know.
And why go to cylindrical coordinates? Cylindrical coordinates are potentially more troublesome since two of the three unit vectors vary with the second coordinate: ur = i cosθ + j sinθ, uθ = -i sinθ + j cosθ.
Anyway, we're reduced to handling the same problem but in cylindrical coordinates, more a math than a physics thing. I have to confess I'm too lazy to work this out with you. Hope someoe else is more amenable!
Both methods are Biot-Savart.
The first one just has cuter math, and I wanted to "plug and chug," I guess. Yes, my question is more mathematically based.
I just worked it out in cartesian coordinates, and the x and y components went away because I was integrating sines and cosines from 0 to 2 pi. THat's nice.
Now why doesn't that happen in cylindrical? It should, right? This should work in any coordinate system. What am I doing wrong? X(
You're right, of course. Has to give the same result either way. Well, maybe I'll have a shot at it but don't hold your breath! Not sure I trust myself working in cylindrical coordinates anymore. Been a loooong time since I did!
OK, here's what I came up with.
Please note all vectors are in bold. er, eθ and k are the unit vectors for the cylindrical coordinate system.
Start with the Biot-Savart formula:
Let c = μ0i/4π to get that mess out of the way for the moment.
Then dB = c(dl x r)/r3
In cylindrial coordinates:
dl = eθ Adθ
r = k z - er A and r = (A2 + z2)1/2
So dl x r = er zAdθ - k A2dθ (set up the usual determinant to get this)
We recognize by symmetry that B will have only a z component, so
dl x r reduces to -k A2
and dB = -k cA2dθ/(A2 + z2)3/2
Finally B = -k cA2∫dθ/(A2 + z2)3/2 from 0 to 2π
& substituting c = μ0i/4π gets us the correct answer.
My problem in general with cylindrical coordinates , and it has no bearing on the above BTW, is this: a cylindrical coordinate system defines a position vector r as follows:
r = er r + k z
when it seems to me it should be
r = er r + eθ θ + k z. Like, how can you define a point with only two coordinates? Yet Thomas (calculus text) and my old mechanics text say the former.
I would love to hear from anyone who can shed some light on this dilemma for me.
FAQ: Mistake with Biot Savart, B of a circular loop integral
1. What is the Biot Savart Law?
The Biot Savart Law is a fundamental law in electromagnetism that describes the magnetic field produced by a current-carrying wire. It states that the magnetic field at a point in space is directly proportional to the current, the length of the wire, and the sine of the angle between the wire and the point.
2. How does the Biot Savart Law apply to a circular loop?
In the case of a circular loop, the Biot Savart Law can be used to determine the magnetic field at any point in space around the loop. The formula for the magnetic field at a point on the axis of the loop is given by: B=μ₀I/2R, where μ₀ is the permeability of free space, I is the current in the loop, and R is the distance from the center of the loop to the point.
3. What is the circular loop integral in the Biot Savart Law?
The circular loop integral is a mathematical tool used to calculate the magnetic field produced by a circular loop. It involves integrating the Biot Savart Law over the entire loop to find the total magnetic field at a point.
4. How do mistakes with the Biot Savart Law occur?
Mistakes with the Biot Savart Law can occur due to errors in calculating the vector cross product or in setting up the integral. It is important to carefully follow the formula and ensure that all variables are correctly accounted for.
5. How can I avoid mistakes with the Biot Savart Law?
To avoid mistakes with the Biot Savart Law, it is important to have a clear understanding of the formula and how to apply it. Double-checking calculations and being mindful of units can also help prevent errors. Additionally, using software or tools designed for calculating magnetic fields can reduce the likelihood of mistakes.
