Mixing two discrete audio signals
In summary, the conversation discusses how to mix two 16 bit PCM audio files without clipping or changing the volume. Options such as adding the signals together and dividing by two are suggested, but it is ultimately determined that it is not possible to achieve both goals simultaneously. The conversation also explores the idea of using a 3dB attenuator to reduce the voltage in the analogue world. The question is raised about how mixing two sound sources on a PC does not result in clipping, and it is suggested that the physics of the real life situation may not follow the same rules as portrayed in teaching.
entropy1
1,231
71
Suppose I have two audiofiles in 16 bit PCM, both recorded on a level that, except for the noise and distortion, is maximally recorded, or that the maximum recording level results in the maximum PCM level. So, the signal is recorded on the maximum level such that there is no clipping.
If we want to mix both files together so that the volume of both audiosignals remain at the same volume, we can:
  1. just add both signals together samplewise. However, now we can have samples in the mix that clip, because the value of the sum of both signals can exceed the 16 bits.
  2. We can add both signals samplewise and divide by two. Now the mix won't have clipping, but the volume of both signals has halved.
So how can we mix the audiofiles without it clipping and without changing the volume?
Mathematics news on Phys.org
What is the sampling rate? I wonder how it would sound taking every other sample from each file, then alternating them. Would that work (with just losing some of the higher frequencies), or would it just sound like garbage?
I don't know the specific PCM format you have - is there an overall scaling information that you can adjust after taking the average for each sample? If not then your sound is already as loud as it can get (for its frequency spectrum), there is no way to get louder sound.
Just adding the samples won't necessarily give the result you expect, however. Imagine both sounds are a sine wave with a phase difference of pi for example: The result will be silence. What you can add easily is the magnitude of the Fourier transformation of your sound, then transform back. That might lead to some unwanted side-effects but it will add the sound intensities as you expect.
If you're doing this in software, can you convert them to a format with more dynamic range, i.e., more bits, before adding them?
Maybe I was not entirely clear. It was ment as a theoretical 'problem' rather than a practical one. So, how can you theoreticly add two PCM signals together, so that their volumes in the mix sound just as loud as in the originals? (and you don't get clipping and distortion?) (see (1) and (2))
I don't see a relevant difference between having two actual files and asking how to add them . and a purely theoretical discussion how you would add them if you would have two actual files.
You can't. There are too many constraints there. As a simple example, suppose you have two different sine waves, each of the maximum amplitude that can be achieved without clipping.
So what would you like to happen when they're in phase? If you retain the same amplitude of each sine wave, you're going to clip. You have in effect asked how to add two numbers between 0 and ##2^n## in such a way that you don't scale either but their sum is still ##\leq 2^n##. You can't achieve all those goals. Something has to give.
Let's assume the signals are white noise. To retain the same volume we must add them so that the total power, and not the voltage, remains the same. In the analogue world we would combine the signals and pass them through a 3dB attenuator. A 3dB attenuator reduces voltage by a factor of 0.707.
I think that in the PCM system we would need to add the two digital samples and then multiply the value by 0.707 to obtain a 3dB reduction. The resulting signal will fit into the 16 bits.
Get 2 sets of amplifier/speakers. Play each file on its own device. Let your ears/brain handle the complexities of mixing the signals :wink:
Likes Tom.G
If I have a soundsource playing through my PC speakers, and I start a second soundsource, I don't perceive any change in volume of the first soundsource. Suppose both soundsources have the same amplitude, and this amplitude is pretty much maximum. Then, if we mix two of them, there must be clipping right? I don't hear any change in volume nor clipping when I start a second soundsource on my PC speakers. How is this possible?
Likes Stephen Tashi
An excellent question!
We can break it into 2 parts( neither of which, I can answer).
1) Does the physics of the real life situation actually say that the result of two pressure waves is the arithmetic sum of the two waves? Thats how we portray transverse waves when we teach about wave interference. However, if we throw a handful of pebbles in a pond, we see interference patterns, but we don't see local maxima in the water level that increase linearly with the number of pebbles thrown. Longitudinal waves are harder to visualize, but I suspect sound waves aren't actually additive.
2) Whatever the physics is, how does our perception combine sounds from different sources?
An interesting webpage on muscial acoustics, http://digitalsoundandmusic.com/chapters/ch4/ says in section 4.1.6.2 that the human ear peforms a frequency analysis of sounds.
Section 4.2.1.5, that same article gives an example of computing the loudness of hearing a lawnmower and a symphony orchestra at the same time. It concludes:
The combined sounds in this case are not perceptibly louder than the louder of the two original sounds being combined.
Likes entropy1
.707 {##1\sqrt(2)##} of the signal voltage would be the RMS value.
Wouldn't this possibly use more bits than the original signals (assuming no cancelation)?
If the signals are noise-like and we use a 3dB attenuator then the signal power is the same. Then if the wave shape is the same the amplitude is the same. If we are dealing with noise-like signals there is always the occasional peak which overloads the system.
If you add two sine waves which are in phase then you need to reduce the input level by 6dB rather than 3dB, because they add on a voltage basis, but this is very unlikely to occur with real sounds.
When you add two noise-like signals, it gives an increase of 3dB, and notice that this is only just audible, as the ear has a log response.
In a practical case I would be surprised if you operated with no headroom to allow for fluctuations in level, so I think it is unlikely that 16 bits are filled.
When dealing with audio levels, also be aware that phase distortion can create a new wave shape having much higher peaks, even though the power remains the same. This new wave does not sound louder and cannot be audibly distinguished from the original. It is uncertain whether a particular microphone and amplifier will maintain zero phase distortion.
FAQ: Mixing two discrete audio signals
1. What is the purpose of mixing two discrete audio signals?
Mixing two discrete audio signals is a common technique used in audio production to combine multiple audio sources into one cohesive sound. This can be used to create a fuller, richer sound or to blend different elements together in a more balanced way.
2. How do you mix two discrete audio signals?
To mix two discrete audio signals, you will need a mixing console or software that allows you to adjust the levels and panning of each signal. Start by setting the levels of each signal so they are balanced, then use panning to position each signal in the stereo field. You can also use equalization and other effects to further shape the sound.
3. What are the different types of mixing techniques?
There are several different mixing techniques, including additive mixing, subtractive mixing, and parallel mixing. Additive mixing involves combining two or more signals together to create a new sound. Subtractive mixing involves removing certain frequencies or elements from a signal to create a more balanced mix. Parallel mixing involves blending a dry signal with a processed signal to add depth and character to the sound.
4. How do you ensure a good mix when combining two audio signals?
To ensure a good mix when combining two audio signals, it is important to listen carefully and make adjustments as needed. Use reference tracks to compare your mix to professionally mixed songs. You can also use tools like compression and EQ to help balance the levels and frequencies of each signal. It is also important to use your ears and trust your instincts when making mixing decisions.
5. Are there any common mistakes to avoid when mixing two discrete audio signals?
One common mistake to avoid when mixing two discrete audio signals is not leaving enough headroom. This means leaving enough space in the overall mix for the audio to breathe and avoiding clipping or distortion. It is also important to use EQ and effects tastefully, as too much processing can muddy the sound. Finally, make sure to constantly reference your mix on different speakers and in different environments to ensure it sounds good across all platforms.
