FaraDazed
- 347
- 2
A mobile phone signal with a frequency of 1945Mhz is being broadcast from a transmitter with a peak output of 3kW.
A: What part of the EM spectrum is the signal. Classify it in terms of its orientation of oscillation and propagation.
B: Write a general equation for the phase θ of this signal in terms of the time t and the displacement from the tower x. Use this equation to calculate the phase at a point t=2μs and x=0.5km. Assume the the phase at the tower at t=0 is zero and the wave travels in the +'ve x direction.
C: At peak power, how many photos per second does the tower produce.
[itex]
y(x,t)=A \sin{(ωt-kx+\theta)}
[/itex]
This questions is from a past exam paper and to me, seems to contain a little stuff maybe we havnt been taught (or that I missed) but I will give it my best shot.
For A:
I know the wave is in the microwave part of the spectrum. But the questions asks to classify it in terms of its orientation of oscillation and propagation, which I am not sure really what its asking. As its an EM wave, surely its oscillating perpendicular to the direction of propagation ( a transverse wave)?
For B:
When the question asks to write a "general equation for the phase of the wave in terms of t and x", is it simply asking for the wave equation [itex]y(x,t)=A \sin{(ωt-kx+\theta)}[/itex] ??
I'm having a bit of trouble with this question as I can't see how one can calculate the amplitude of the wave at all, unless it relies on the information at t=0 the phase is zero? Also what does y(x,t) reprsent as sureley one would need to know a value for that to calculate the phase? All I have done so far is this...
First I calculated the wavelength, wavenumber and angular velocity
[itex]
\lambda=\frac{c}{f}=\frac{3 \times 10^{8}}{1945 \times 10^6}=0.154m \\
k=\frac{2 \pi }{\lambda}=\frac{2 \pi }{0.154}=40.8 m^{-1} \\
ω= 2 \pi f = 2 \pi (1945 \times 10^6) = 1.22 \times 10^{10}
[/itex]
And then popped all I know into the wave equation
[itex]
y(x,t)=A \sin{(ωt-kx+\theta)} \\
y(x,t)=A \sin{((1.22 \times 10^{10})(2 \times 10^{-6})-(40.8)(500)+\theta)} \\
y(x,t)=A \sin{(24400-20400+\theta)} \\
y(x,t)=A \sin{(4000+\theta)} \\
[/itex]
I could isolate theta but still without knowing more its of no use. I wonder if the power output of the transmitter relates to the amplitude somehow?
For C:
I have no clue whatsoever where to start with this. I assume the power output has something to do with it but I don't even know what to research/lookup to find out how to solve that bit.
Any help is very much appreciated :) .
