Model of no-slip wheel with eccentric center of mass problem
In summary, you need to include the Coriolis term in your equation of motion to accurately model the motion of your system.
blamking
This is actually part of a much bigger goal, but I have isolated the problem I am having, which I have been struggling with for quite a while. I feel like the problem may be obvious to someone here.
I attached a diagram of the problem to try to help illustrate it.
Assume there is a massless wheel (in the xy-plane) of radius R that can roll with no slip on a horizontal surface. Rigidly attached to the wheel at a distance L away from the center is a point mass, m. Only the wheel makes contact with ground. My goal is to find how this system acts over time.
Kinematic equations for relative acceleration
sum of forces = ma
sum of moments = Iα
Kinematic equations of particle rectilinear motion and rotation about a fixed axis.
N is the normal force between the ground and point of contact on the wheel. fx is the force of friction between the wheel and ground. θ is the angle between the x-axis and the vector between the center of the wheel and the point mass. I is the moment of inertia, ax and ay are the components of the acceleration of the point mass, α is the angular acceleration of the system, and ω is the angular velocity.
The following are my interpretation of the kinematic equations for relative acceleration, the sum of the forces, and the sum of the moments around the point mass. I then use these equations to solve for the linear and rotational accelerations, the normal force, and the friction force given the rest of the variables.
[itex]a_x+\alpha(R+Lsin(\theta))=-\omega^2Lcos(\theta)[/itex]
[itex]a_y-\alpha(Lcos(\theta))=-\omega^2Lsin(\theta)[/itex]
[itex]-ma_x+f_x=0[/itex]
[itex]-ma_y+N=mg[/itex]
[itex]-I\alpha-NLcos(\theta)+f_x(R+Lsin(\theta))=0[/itex]
Once I have these, I update. px and py are the coordinates of the point mass, and vx and vy are the components of the velocity.
[itex]p_{x_{k+1}} = p_{x_k} + v_{x_k}{\Delta}t+a_{x_k}{\Delta}t^2/2[/itex]
[itex]p_{y_{k+1}} = p_{y_k} + v_{y_k}{\Delta}t+a_{y_k}{\Delta}t^2/2[/itex]
[itex]\theta_{k+1} = \theta_k + \omega_k{\Delta}t+\alpha_k{\Delta}t^2/2[/itex]
[itex]v_{x_{k+1}} = v_{x_k}+a_{x_k}{\Delta}t[/itex]
[itex]v_{y_{k+1}} = v_{y_k}+a_{y_k}{\Delta}t[/itex]
[itex]\omega_{k+1} = \omega_k+\alpha_k{\Delta}t[/itex]
I then proceed to calculate the updated coordinates of the center of the wheel, which I'll call qx and qy.
[itex]q_x = p_x - Lcos(\theta)[/itex]
[itex]q_y = p_y - Lsin(\theta)[/itex]
This is where I run into problems. Logically, the wheel would retain the same y-coordinate between all time steps, since it is rolling on the ground. However, when I run my model for several time steps, it will leave the ground. Decreasing the time step decreases the magnitude of the problem, but never to the point where it is negligible. I've been thinking that since the rotation axis technically translates, the rotation kinematic equations might not be applicable in the form that I have them? Maybe I need to include Coriolis terms in my relative acceleration equations? It seems that everything I try only makes the problem worse, so i could really use some advice.
I also don't really want any huge reorganization of my approach to solving this problem unless there is no alternative, since, as I mentioned before, this is part of a bigger problem which is imposing some constraints on how I do things.
Anyway, thanks in advance, and please let me know if I need to clarify anything.
The solution:The problem is that you are not taking into account the translation of the point of rotation. The equations of motion for a particle in rectilinear motion and rotation around a fixed axis assume that the point of rotation does not move. In your case, the point of rotation is moving. Therefore, you need to use the equation of motion for a particle in rectilinear motion and rotation around a moving axis. This equation adds an additional Coriolis term to the equation for angular acceleration.The final equation of motion for your system is as follows:-ma_x+f_x=0-ma_y+N=mg-I\alpha-NLcos(\theta)+f_x(R+Lsin(\theta))=2m\omega v_{x_k}where v_{x_k} is the x-component of the velocity of the point of rotation.Once you have this equation, you can then proceed to solve for the linear and rotational accelerations, normal force, and friction force given the rest of the variables, using the same approach as before.
FAQ: Model of no-slip wheel with eccentric center of mass problem
1. What is a no-slip wheel with eccentric center of mass problem?
A no-slip wheel with eccentric center of mass problem is a physics concept that involves a wheel with a mass that is not evenly distributed around its center. This creates a challenge in predicting the motion of the wheel, as the non-uniform mass distribution affects its rotational motion.
2. What is the significance of studying this problem?
Studying the no-slip wheel with eccentric center of mass problem has practical applications in engineering and design, as it is relevant to the motion of wheels in vehicles such as cars and bicycles. It also helps in understanding rotational dynamics and conservation of angular momentum.
3. How is the motion of the wheel affected by the eccentric center of mass?
The eccentric center of mass causes the wheel to experience a torque, which results in a change in its rotational motion. This means that the wheel will not roll smoothly and will have a tendency to wobble or veer off its intended path.
4. Can this problem be solved using mathematical equations?
Yes, this problem can be solved using equations from rotational dynamics and conservation of angular momentum. By considering the forces acting on the wheel, the torque caused by the eccentric center of mass, and the conservation of angular momentum, the motion of the wheel can be predicted and analyzed.
5. Are there any real-life examples of this problem?
Yes, the no-slip wheel with eccentric center of mass problem can be observed in real-life situations such as a bicycle wheel with a weight attached to the rim or a car wheel with a dent on one side. In both cases, the motion of the wheel is affected by the non-uniform distribution of mass.
