Model of parachute that doesn't include gravity
In summary, a question was posted about why gravity was not accounted for in a physics problem involving a skydiver and a parachute. The problem provided the weight of the skydiver and the drag force of the parachute, and asked for the magnitude and direction of the skydiver's acceleration. The person asking the question did not see why gravity would not be included in the net force, as it was acting in a downward direction. However, the responder pointed out that the weight of the skydiver is another way of stating the gravitational force, and this force is already included in the problem. The responder also noted that the term "weight" is commonly used to refer to gravitational force in many physics and aerodynamics texts.
hholzer
37
I'll post this question here because it isn't a homework question.
I've already solved this problem that I have taken from a physics
book. My question pertains to why would gravity not be accounted
for? (The reason I think no gravity is account for is because the
solution provided by the book does not include gravity as a force
a part of the net force.).
The problem is as follows:
"When a parachute opens, the air exerts a large drag force on it.
This upward force is initially greater than the weight of the sky diver
and, thus, slows him down. Suppose the weight of the sky diver is
906 N and the drag force has a magnitude of 1105 N. The mass of
the sky diver is 92.4 kg. What are the magnitude and direction of his
acceleration?"
This is a clear problem of sum(F_i) = ma -- where 'a' is a vector quantity
and each F_i corresponds to a force that makes up the net force.
Why would gravity(acting in a downward direction) not be included
in the net force? I don't see anything in the problem which might
indicate that it should be ignored.
Your right. The question is clearly rubbish.
Isn't 'the weight of the sky diver' the gravitational force?
It isn't clear to me why you would consider them the same.
Could you elaborate on this?
acceleration?"
(thread moved to HH/Intro Physics. Even if the problem is for self-study, it belongs here. Dem's the Rules)
On your question -- you are given the weight of the skydiver. What force causes that weight?
Two reasons:
1. You are given that the "weight of the sky diver is 906 N". What else is this other than the gravitational force on the skydiver?
2. That weight is a synonym for gravitational force is the most widespread meaning of the word "weight", particularly so in most introductory physics texts and in most aerodynamics texts (regardless of level).
FAQ: Model of parachute that doesn't include gravity
How does a parachute work without gravity?
A parachute works by creating drag, or air resistance, as it falls through the air. This drag slows down the descent of the parachute and its attached object, allowing for a safe landing. Gravity is not the only force that affects the descent of a parachute.
What other factors besides gravity affect the descent of a parachute?
Air density, air pressure, and surface area of the parachute all play a role in the descent of a parachute. Air density and pressure can affect the amount of drag produced, while the surface area of the parachute can determine how quickly the parachute falls through the air.
Can a parachute still work in a vacuum without gravity?
No, a parachute would not work in a vacuum without gravity. Without air resistance, there would be no drag force to slow down the descent of the parachute. Gravity is also necessary for the parachute and its attached object to fall towards Earth.
How can a parachute be designed to work without gravity?
Some potential designs for a parachute that could work without gravity include using a different gas or liquid for drag, such as helium or water, or using a different type of material that can create enough drag in a vacuum. However, these designs have not yet been tested and proven to be effective.
Are there any real-world applications for a parachute that doesn't rely on gravity?
Currently, there are no known real-world applications for a parachute that does not rely on gravity. However, further research and development could potentially lead to new uses for a parachute in environments with different levels of gravity or where gravity is not present at all.
