Modelling a metal detector using eddy currents from Non-Destructive Testing
The discussion focuses on modeling a metal detector using eddy currents for an internship project. The system involves a coil energized by an oscillator to generate a magnetic field, with detection based on changes in coil impedance. The magnetic field produced by the coil is described using Biot-Savart law, while induced voltage in the target is determined by Faraday's law. The user seeks to find the expression for the magnetic field induced by eddy currents, specifically questioning if it takes a form like Bind = B0eiwt. The request for assistance emphasizes the need for results to initiate simulations and includes links to relevant resources for further clarification.
Sh_lm
∇×E=− ∂/∂t(∇×B)
∇×B=μ0ε0∂/∂t(E)
I'm trying to model a metal detector for my internship project.
The system consist of one coil energised with an oscillator to create a magnetic field. The principle of the detection is by measuring the change in the coil impedance.
with biot et savart law the magnetic field create by the coil is expressed
where
Bem(r) : the magnetic field create by the coil
N : number of loops
Iem : current flowing through the coil
Rem : radius of the coil
r : distance from a given point in space to a point on the perimeter of the coil
The induced voltage in the target is given with faraday's law
where phi is the magnetic flux
I'm trying to find the expression of Bind the magnetic induced by eddy currents.
This is my results :
Now I've got a problem. Does Bind have a particular form? something like Bind = B0eiwt? or anything else? I need these results to start simulations so any help is welcomed thank you very much
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
