Modified gravitation ; how to make it relativistic ?
In summary: GR is a theory of gravity that emerged from Einstein's general theory of relativity, while Newtonian gravity is the classical theory of gravity.So your question does not make sense to me. In summary, Rudi Van Nieuwenhove proposes that Newtonian gravity should be modified to include a relativistic correction, but it is too simplistic.
notknowing
185
Suppose one is not happy with Newton's law of gravitation and finds that it should be modified and that one has an equation describing the gravitational potential
[tex] \phi [/tex] in function of radius. If one then want to obtain a relativistic description, would it be sufficient to replace in the Schwarzschild metric the term(s)
[tex]
\left(\ 1 - \frac {2 G M} {c^2 r} \right)
[/tex]
by
[tex]
\left(\ 1 + \frac {2 \phi} {c^2 } \right)
[/tex]
or would that be to simplistic?
"would that be too simplistic?"
Probably (almost certainly) yes, but it would likely be a good first approximation.
Jim Graber
Too simplistic, in all likelihood. If you want more detail I think you'll have to be more specific concerning the modification you have in mind. Providing some rationale for your proposed nonrelativistic correction would probably also be appropriate!
The modification I had in mind is described in : http://arxiv.org/abs/0712.1110
I expected that it was too simplistic, but I don't exactly understand why. If I look for instance in the book Gravity, An Introduction to Einstein's general relativity by James B. Hartle, I find that the derivation of the metric for the static weak field metric (eq. 6.20 on page 126) would have exactly the same form if [tex] \phi [/tex] would have a different radial dependence, or am I wrong? And if it is too simplistic, what would be the correct way to make it relativistic? Or what objection could be made to the simple replacement of [tex] \phi [/tex] with a different radial dependence in the Schwarzschild metric? What physical principles would it violate?
Rudi,
What action do you have that generates your metric?
Garth
Garth said:
Rudi,
Garth
For the moment I have neither a metric nor an action. The only thing I have is a simple potential. What would prevent me from using the replacement described in my earlier post?
Certainly, the weak field limit should produce [tex]g_{00} = 1+2\phi(r)[/tex], so in that sense it seems reasonable as a first approximation (as others have echoed already). I think it depends on the form of the potential, and how it depends on the radial coordinate. If you consider the extra-dimensional Schwarzschild metric, it follows the pattern you suggest, e.g.:
[tex]g_{00} = 1-\left(\frac{r_H}{r}\right)^{n+1}[/tex]
which we know is an exact solution (derived from the action) and basically boils down to substituting the [tex]n+1[/tex]-dimensional potential. I would think that as long as the potential follows a power-law behavior, you're good to go (but in that case you're not proposing something radically different).
That being said, I think you've raised an interesting question, because it's not one that I've seen explained with any high degree of satisfaction.
Rudi,
you start by proposing that if Newtonian gravity is not satisfactory and should be modified, that we should modify GR. Metrics are not part of Newtonian gravity so you are proposing modifying GR ( ?) because N. gravity is no good. Your question does not make sense to me.
As has been pointed out, Newtonian gravity emerges as a weak field solution in GR. But GR and Newtonian gravity are separate and different theories.
FAQ: Modified gravitation ; how to make it relativistic ?
How does modified gravitation differ from traditional gravitation theories?
Modified gravitation, also known as modified gravity, is a theory that aims to explain the behavior of gravity at large scales. Unlike traditional theories of gravitation, such as Newton's law of universal gravitation and Einstein's theory of general relativity, modified gravitation theories propose modifications to the fundamental equations of gravity in order to account for observations that cannot be explained by traditional theories.
What are some examples of modified gravitation theories?
Some examples of modified gravitation theories include MOND (Modified Newtonian Dynamics), TeVeS (Tensor-Vector-Scalar gravity), and f(R) gravity. These theories differ in their specific modifications to the equations of gravity, but all aim to explain phenomena that cannot be explained by traditional theories.
How does modified gravitation relate to the concept of relativity?
Modified gravitation theories often incorporate elements of relativity, as they aim to explain observations at large scales where traditional theories of gravity break down. However, these theories also propose modifications to the equations of relativity in order to better fit observations. Therefore, modified gravitation can be seen as an attempt to reconcile the theories of gravity and relativity.
Can modified gravitation be tested experimentally?
Yes, modified gravitation theories can be tested experimentally. Many of these theories make predictions that can be tested through observations of astronomical phenomena, such as the rotation of galaxies or the bending of light by massive objects. However, due to the complexity of these theories, it can be challenging to design experiments that can definitively prove or disprove them.
What are the implications of a successful relativistic modified gravitation theory?
If a modified gravitation theory that is also relativistic is proven to be true, it would have major implications for our understanding of the universe. It would mean that our current understanding of gravity and relativity is incomplete and would require a significant shift in our understanding of these fundamental concepts. It could also lead to new insights and advancements in fields such as cosmology and astrophysics.
