MHB Modulos with regards to Congruence
  • Thread starter Thread starter shamieh
The discussion focuses on solving the congruence equation 34x ≡ 77 (mod 89), specifically the reversing part of the problem. To solve this, one must find the multiplicative inverse of 34 modulo 89, which is calculated using the extended Euclidean algorithm, yielding 34^{-1} ≡ 55 (mod 89). This inverse allows for the equation to be manipulated into the form x ≡ 77 * 55 (mod 89). The final solution is determined to be x ≡ 52 (mod 89). Understanding the process of finding the inverse is crucial for solving similar congruences effectively.
shamieh
Can someone explain to me what exactly is taking place on Section 4.4 Problem 6b) in the reversing part of the problem? I understand the first part - that's easy, but I have no idea what is going on in the reversing part of the problem. Thanks in advance.
Here is a link instead of me typing tediously:
The problem reads:
Solve $34x ≡ 77 (mod 89)$
http://www.cs.ucsb.edu/~omer/cs40/hw4_solutions.pdf
The problem reads:
A congruence equation of the type...
$\displaystyle n\ x \equiv m\ \text{mod}\ p\ (1)$
... is solved as follows... indicating with $n^{-1}$ the multiplicative inverse of n mod p [if it exists...], You have...
$\displaystyle n\ n^{-1} x = x \equiv m\ n^{-1}\ \text{mod}\ p\ (2)$
You can find $n^{-1}\ \text{mod}\ p$ applying, for example, the extended Euclidean algorithm [see Modular multiplicative inverse - Wikipedia, the free encyclopedia ]... in Your case is n = 34, m = 77 and p = 89, so that is $34^{-1}\ \text{mod}\ 89 = 55$ and the solution is $\displaystyle x \equiv 77 \cdot 55\ \text{mod}\ 89 = 52$ ...
Kind regards
$\chi$ $\sigma$
Hello, I'm joining this forum to ask two questions which have nagged me for some time. They both are presumed obvious, yet don't make sense to me. Nobody will explain their positions, which is...uh...aka science. I also have a thread for the other question. But this one involves probability, known as the Monty Hall Problem. Please see any number of YouTube videos on this for an explanation, I'll leave it to them to explain it. I question the predicate of all those who answer this...
I'm taking a look at intuitionistic propositional logic (IPL). Basically it exclude Double Negation Elimination (DNE) from the set of axiom schemas replacing it with Ex falso quodlibet: ⊥ → p for any proposition p (including both atomic and composite propositions). In IPL, for instance, the Law of Excluded Middle (LEM) p ∨ ¬p is no longer a theorem. My question: aside from the logic formal perspective, is IPL supposed to model/address some specific "kind of world" ? Thanks.
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
