What Is the Molar Heat of Transformation for Phosphine at 30.29 K?
In summary, the molar heat of transformation for the γ form changing to the α form at 30.29 K can be obtained by calculating the total entropy change, which is the sum of the individual entropies of the system. Using the given data, the total entropy change is 25.15 J/mol K. This can then be used to calculate the latent heat, which is 761.79 J/mol.
patrickmoloney
94
[/B]
Phospine exist in three forms. known as the [itex]\alpha[/itex], [itex]\beta[/itex] and [itex]\gamma[/itex] forms. The [itex]\alpha[/itex] and [itex]\beta[/itex] forms are in equilibrium with each other at [itex]49.43 \, K[/itex], and the [itex]\alpha[/itex] and [itex]\gamma[/itex] forms are in equilibrium at [itex]30.29 \, K[/itex]. Obtain the molar heat of transformation for the [itex]\gamma[/itex] form changing to the [itex]\alpha[/itex] form at [itex]30.29 \, K[/itex] from the following data:
(i) The entropy of the [itex]\alpha[/itex] at [itex]49.43 \, K[/itex] is [itex]34.03 \, \text{J/mol K}[/itex].
(ii) The change in entropy heating the [itex]\gamma[/itex] from [itex]0\, K[/itex] to [itex]30.29 \, K[/itex] is [itex]11.22 \, \text{J/mol K}[/itex].
(iii)The change in entropy in heating the [itex]\alpha[/itex] form from [itex]30.29 \, K[/itex] to [itex]49.43 \, K[/itex] is [itex]20.10 \, \text{J/mol K}[/itex]
The relationship between latent heat [itex]Q_T[/itex] and molar entropy [itex]\Delta S[/itex] is
[tex]Q_T = \Delta S \cdot T[/tex]
[itex][/itex]
The total entropy is calculated by adding the individual entropies of the system.
Using the data given we know that [itex]S_{\alpha} = 34.03\, \text{J/mol K}[/itex] at [itex]49.43\, K[/itex]
We also know that the entropy change [itex]\Delta S_{{\alpha}_2}= 20.10\, \text{J/mol K} [/itex] from [itex]30.29 \, K \to 49.43 \, K[/itex]
Hence,
[tex]\Delta S_{\alpha_{1}}= S_{alpha}- \Delta S_{\alpha_{2}} = 34.03 - 20.10 = 13.93 \, \text{J/mol K} [/tex]
is the entropy change in heating the [itex]\alpha[/itex] form from [itex]0 \, K \to 30.29\, K[/itex]
We know the entropy change for [itex]\gamma[/itex] is [itex]\Delta S_{\gamma}= 11.22[/itex]
There for the total entropy [itex]\Delta S_{tot}[/itex] is given by
[tex]\Delta S_{tot} = \Delta S_{alpha_{1}} + \Delta S_{\gamma}= 13.93 + 11.22 = \, 25.15 \text{J/mol K}[/tex]
Our latent heat is
[tex]Q = \Delta S_{tot}\cdot T = (25.15\, \text{J/mol K})(30.29 \, K)= 761.79 \, \text{J/mol}[/tex]is this a correct way to tackle this problem. I struggled for a while cause it's a bit of a weird problem but is it really that straight forward or am I missing something. As they say if physics seems easy - you're doing it wrong.
No. You want the change in entropy on going from γ to α. That is Sα - Sγ.
Related to What Is the Molar Heat of Transformation for Phosphine at 30.29 K?
1. What is the molar latent heat of phosphine?
The molar latent heat of phosphine is the amount of energy required to change one mole of phosphine from a liquid to a gas at constant temperature and pressure.
2. How is the molar latent heat of phosphine measured?
The molar latent heat of phosphine can be measured experimentally by using a calorimeter to measure the heat released or absorbed during the phase change from liquid to gas.
3. What is the significance of the molar latent heat of phosphine?
The molar latent heat of phosphine is important in understanding the behavior of phosphine as a gas at different temperatures and pressures. It also has practical applications in industries such as refrigeration and cryogenics.
4. What factors affect the molar latent heat of phosphine?
The molar latent heat of phosphine is affected by the temperature and pressure at which the phase change occurs. It also varies depending on the purity of the phosphine sample and any impurities present in the sample.
5. How does the molar latent heat of phosphine compare to other gases?
The molar latent heat of phosphine is relatively low compared to other gases, such as water vapor or ammonia. This means that it requires less energy to change phosphine from a liquid to a gas compared to these other substances.
16K
