Molecular formula of S in benzene
In summary, the molal freezing point depression constant of benzene is 5.07 K kg/mol. A .45% solution of monoclinic sulfur in benzene freezes .088K below the freezing point of pure benzene. Find the molecular formula of sulfur in benzene.
Puchinita5
183
The molal freezing point depression constant of benzene is 5.07 K kg/mol. A .45% solution of monoclinic sulfur in benzene freezes .088K below the freezing point of pure benzene. Find the molecular formula of sulfur in benzene.
Can someone tell me if the answer is S2 ?
I guess I'm not 100% sure about what exactly I'm looking for.
What I did was say that if there was 100g of solution, then
100g *(.45)*(1/32.1)=1.402 moles of sulfur
100g *(.55)*(1/78.1)=0.704 moles of benzene
then divided them which gave about 2 moles of sulfur per benzene.
But 1) I never used the molality from the freezing point depression which makes me think I'm definitely wrong and 2) I'm just not sure if it makes sense to find moles of sulfur per moles of benzene.
any insight? This was on my quiz today and I won't rest until I know how wrong I was! lol.
Well, I know that the molality is moles of solute per kg of solvent.
So for this problem, the molality of sulfur in benzene is .088/5.07= 0.017357
But I'm not sure what I can do with this to get the molecular formula of sulfur.
Use this information to calculate molar mass of solute.
I am getting something obviously very wrong.
if the molality is .017 mol s /kg benz then...
(.017 mol S / 1000 g B)*(.55 g B / g total) * (1 g total / .45 g S) = .0000208 mol S / g S
so the molar mass would be the recipcrocal or 48128 g S / mol S. Which is just ridiculously high.
So i obviously still don't know what i am doing. I would assume, if this were right, that i would take this molar mass and divide it by the molecular weight of S.
But with this number that would give me S 1468 , which just can't be right.
What am I doing wrong?
I must confess I never use dimensional analysis for these things and I am not even sure if it makes any sense here. This means I can't help you showing what you did wrong. However, I can help you solve the problem using slightly different approach.
How many moles of solute is present in 1000g of solution? What is mass of this solute? Can you combine these two numbers to calculate molar mass?
Well, there should be
(.017 mol S / 1000 g B) * (.55 g B / g sol) = .00935 mol S / 1000 g solution
But without knowing how much solution there is, I can only say that there is
(.00935 mol S / 1000 g sol )*(32.1 g S / 1 mol S)= .3001 g S / 1000 g sol = .0003 g S / g sol
But this doesn't help me see anything differently
to get back to molar mass I would have to take .0003 g S / g sol and divide by 32.1 (basically undoing what I had done in the previous step) and then dividing by .45.
this gives me the same number I got before.
so lost
I told you to assume 1000g of solution. Use molality definition - rearrange it to find number of moles (iow solve it for number of moles). 1000g of solution contains 99.55% of solvent (100%-solute).
Actually you can assume any other amount of solution (like 100g, 500g, 3.1415g and so on), final result will be identical. You can even assume msolution and solve the problem using symbols - in the end msolution will cancel out.
OH...now i see what my mistake was.
I didn't realize it was .45 PERCENT. I was wondering where you got 99.55%. I was basiclaly doing my calculations for a 45 percent solute solution and 55 percent solvent.
So I end up with a molar mass of 265.9 which is 8.28 times larger than the molar mass of sulfur.
so I guess the molecular formula should be S8 ?
::sigh:: which means I was definitely wrong on my quiz today.
You are definitely in my class, and i can't believe we are the only two nerds checking for this on a friday. lol. if it makes u feel any better, i got that question wrong too. I calculated the mb, I am hoping for partial credit. :-(
hahha i remember you! I definitely was a little grumpy after this quiz...especially now that I know how to solve it and can see how easy it was! I don't like when he throws random surprises like that on the quizzes. The second I looked at the question I think my brain shut off because I panicked since it wasn't something I remembered solving in class or homework. Maybe if he would have given more time I would have figured it out, or not. But these last few quizzes have definitely not gone so hot for me!
lol. kudos for solving it tho! I was still scratching my head, if he gives us a 're-take' we will be ready. ha ha. and yes these last couple of quizzes have been awkward... lol. but i gained a lil confidence after the re-take he gave on wednesday (he should do more of those) lol. by the way was the first diagram a non-ideal azeotrope at low boiling?
I don't remember, did it ask about an azeotrope? All I remember was that A boiled at a lower temperature than B.
i don't remember what the question was exactly. It didn't say azeotrope though. If it said at two different boiling points, then you might be right. From what I remember it said "Draw a Liquid-vapor diagram that boils at lower temperature." Which is why i drew azeotrope. If he did include A & B then it would be the ideal solution diagram you described.
This is what 'I' remember the questions being.
For the first diagram it said. Draw a Temperature vs. Composition diagram at low boiling temperature. Draw 2 theoretical plates.
For the second it said. Draw a Temperature vs. Composition diagram of two mixtures A & B and something about the eutectic.
For the second graph I'm sure he mentioned two different components. for the first graph I am not sure he mentioned any components.
This is off topic. You can discuss it using PMs.
Related to Molecular formula of S in benzene
1. What is the molecular formula of S in benzene?
The molecular formula of S in benzene is C6H6S.
2. How is the molecular formula of S in benzene determined?
The molecular formula of S in benzene is determined by the number of atoms of each element present in the molecule. In this case, there is one atom of sulfur (S) present in the molecule.
3. What is the significance of sulfur in the molecular formula of benzene?
Sulfur (S) is an important element in the molecular formula of benzene as it contributes to the overall structure and properties of the molecule. It also plays a role in the reactivity and chemical reactions of benzene.
4. Is sulfur the only element present in the molecular formula of benzene?
No, sulfur is not the only element present in the molecular formula of benzene. It is also composed of carbon (C) and hydrogen (H) atoms in a specific arrangement.
5. How does the molecular formula of S in benzene differ from other compounds?
The molecular formula of S in benzene differs from other compounds in terms of the specific arrangement and number of atoms of each element present. This unique combination of atoms gives benzene its distinct properties and characteristics.
