Molecular work in an Adiabatic process ?
In summary: I understand now. In summary, the molecules in the packet are doing work as the air parcel expands, which decreases the temp.
karen_lorr
63
Molecular "work" in an Adiabatic process ?
I have studied Adiabatic cooling in connection with a rising parcel of air. I’m confused. I understand that temperature is a macroscopic principle (not a Microscopic); molecules do not have a temperature, only velocity and Kinetic energy. I have read that there is no heat loss (heat being the amount of work available from a system)
I have read the molecules in the packet are doing “work” as the air parcel expands – what work are they doing ?
If the total energy remains the same (1st law T’m’d) surely the molecules are expending energy?
I have read so many pages concerning the adiabatic process that you’d think I’d have it by now, but I just confused.
Can anyone give any insights into this topic?
Thank you
Thank you
You are losing heat, just not to your surroundings. Adiabatic cooling just means to reduce the temp by reducing the pressure rather than through heat transfer (transfer of momentum between molecules).
With cooling the molecules do work to expand the size of the parcel which decreases the temp. With heating external work is done to increase the pressure which increases the temp.
Just to add to what LostConjugate has said, the expanding gas does work on the surrounding air mass because it has to push the surrounding air over some distance: This work is [itex]W = \int PdV (= \int (F/A)Ads = \int Fds)[/itex]. Since there is no heat flow into or out of the air, this work comes at the expense of its internal energy: dQ = dU + dW. dQ = 0 -> dU = - dW. So [itex]W = -nCv\Delta T[/itex]
The total energy of the expanded gas does not remain the same. It decreases. The molecules in the original sample expend some of their kinetic energy to do work on the surrounding air. So the temperature of that original mass of air decreases. That energy has gone into the surroundings in some form. The form will depend on how the nature and configuration of the surroundings.
AM
Ahh, I have it now
Thank you both
for your question. I can understand your confusion as the concepts of temperature, heat, and work can be quite complex and interconnected. Let me try to provide some clarification on the topic of molecular "work" in an Adiabatic process.
Firstly, it is important to understand that temperature is indeed a macroscopic property and is a measure of the average kinetic energy of a large group of molecules. However, individual molecules do have kinetic energy and can transfer this energy to other molecules through collisions. This energy transfer is what we refer to as heat.
In an adiabatic process, there is no heat exchange between the system (air parcel) and its surroundings. This means that there is no transfer of energy through collisions between molecules and the surrounding air. However, this does not mean that there is no work being done by the molecules in the air parcel.
As the air parcel rises, it expands due to decreasing atmospheric pressure. This expansion means that the individual molecules within the parcel are moving further apart from each other. To maintain the same temperature, the molecules must increase their kinetic energy, which means they are doing work on each other.
Think of it this way: when you pump air into a bicycle tire, you are doing work on the air molecules by compressing them closer together. Conversely, when you release the air, the molecules expand and do work on the surrounding air by pushing it out of the tire. Similarly, in an adiabatic process, the molecules are doing work on each other by expanding and pushing each other away.
So, in summary, in an adiabatic process, the molecules are not exchanging heat with their surroundings, but they are still doing work on each other by expanding and increasing their kinetic energy. I hope this helps to clarify any confusion you may have had on the topic.
FAQ: Molecular work in an Adiabatic process ?
What is a molecular work in an adiabatic process?
Molecular work in an adiabatic process refers to the transfer of energy between molecules without any heat exchange with the surroundings. This type of work occurs in a closed system where there is no heat flow in or out.
How is molecular work related to adiabatic processes?
In an adiabatic process, the change in energy is solely due to the work done by or on the system. This work is typically in the form of molecular work, where molecules interact and transfer energy without any heat exchange.
What factors affect molecular work in an adiabatic process?
The amount of molecular work in an adiabatic process is affected by the number of molecules present, the temperature of the system, and the type of molecules involved. Additionally, external factors such as pressure and volume can also influence molecular work.
What are some real-life examples of molecular work in an adiabatic process?
Some examples of molecular work in an adiabatic process include the compression or expansion of gases in an engine, the compression of air in a bicycle pump, and the expansion of gas in a balloon. These processes involve molecules interacting and exchanging energy without any heat transfer.
How is molecular work calculated in an adiabatic process?
The amount of molecular work in an adiabatic process can be calculated using the formula W = -PΔV, where W is the work done, P is the pressure, and ΔV is the change in volume. This formula assumes that the process is reversible and that there is no change in temperature during the process.
