Why Does Momenergy Have a Magnitude Equal to Mass?
In summary, the momenergy of a particle is a 4-vector that is proportional to its mass and is reckoned using the proper time for the particle's displacement. This is the relativistic definition of mass and it is the simplest definition that satisfies the necessary conditions. The magnitude of the four-momentum is not only proportional to the mass, but it is also equal to the mass. This definition is unique and cannot be defined in any other frame-independent way.
Ashshahril
Why momenergy has magnitude equal to the mass?
$$\textbf{(momenergy)} = \text{(mass)} \times \frac{\textbf{(spacetime displacement)}}{\text{(proper time for that displacement)}}$$
> The mom-energy of a particle is a 4-vector: Its magnitude is proportional to its mass, it points in the direction of the particle's spacetime displacement, and it is reckoned using the proper time for that displacement. How are these properties combined to form momenergy? Simple! Use the recipe for Newtonian momentum: mass times displacement divided by time lapse for that displacement. Instead of Newtonian displacement in space, use Einstein's displacement in spacetime; instead of Newton's "universal time," use Einstein's proper time."
Statement from: [Spacetime Physics; Wheeler & Taylor; Chapter 7](https://www.eftaylor.com/spacetimephysics/07_chapter7.pdf)
From the same chapter:
> **Statement 6: The momenergy 4-vector of the particle is**
> Reasoning: There is no other frame-independent way to construct a 4-vector that lies along the worldline and has magnitude equal to the mass.
In the first statement, it says, "magnitude is proportional to its mass" and in the second one, it says, "magnitude equal to the mass". Why two different statements?
Proportional to the mass means, sometimes, it can be equal to the mass. But in all cases? Can it be true? You may say, the author said,
>. As the value of spacetime displacement and proper time for that displacement are the same, so, "magnitude equal to the mass". But remember, he said "magnitude equal to the mass" to establish this formula.
So, the question: Why it has magnitude equal to the mass?
You can find the full contents of the book from [here](https://www.eftaylor.com/spacetimephysics/). Its under creative commons license.
Because this is the relativistic definition of mass - the magnitude of the 4-momentum (which is the usual modern name for what you call momenergy).
Taylor and Wheeler note that it makes physical sense for the four-momentum to be proportional to the mass, and they give the simplest definition that satisfies the various conditions they want for the four-momentum. Once you have this definition, then you find that the magnitude of the four-momentum is not only proportional to the mass but is actually equal to the mass. In the reasoning for statement 6, they're saying there is no other way to define the four-momentum in a frame-independent way so it will have these properties. The definition is unique.
FAQ: Why Does Momenergy Have a Magnitude Equal to Mass?
What is Momenergy?
Momenergy, or momentum-energy, is a concept in physics that describes the combined quantity of an object's momentum and energy. It is a measure of how much motion and how much energy an object has.
How is Momenergy calculated?
Momenergy is calculated by multiplying an object's mass by its velocity (momentum) and adding it to its kinetic energy (energy of motion). The equation is: Momenergy = mass x velocity + 1/2 x mass x velocity^2.
What is the significance of Momenergy?
Momenergy is significant because it helps us understand how objects move and interact with each other. It is also a conserved quantity, meaning it remains constant in a closed system, making it a useful tool in analyzing physical systems.
How does Momenergy relate to other concepts in physics?
Momenergy is closely related to other fundamental concepts in physics, such as Newton's laws of motion, conservation of energy, and work. It is also a key component in understanding concepts like collisions, impulse, and momentum transfer.
Can Momenergy be negative?
Yes, Momenergy can be negative. This can occur when an object is moving in the opposite direction of its momentum, or when an object has negative kinetic energy (such as an object at rest). However, the overall Momenergy of a closed system will remain constant, even if individual components have negative values.
