Moment Deflection Relationship Problem
In summary, an electrical engineer is trying to optimize the angle at which a thin Cu "finger" contacts a Si wafer, in order to improve the signal in his electrical work. The engineer believes that a point contact is causing poor signals and wants to achieve an "area contact" without permanently deforming the finger. The finger can be modeled as a cantilever beam and to find the optimum angle, the maximum stress in the beam must approach the yield strength of copper. The calculation involves using the equations for slope and deflection, as well as considering the geometry and material properties of the beam and wafer.
simonsid
An electrical engineer in your semiconductor company is working on a design of an electrical contact with a Si wafer. The electrical contact is in the form of a thin Cu “finger” touching the back side of a wafer as shown below. The electrical engineer claims that he is getting poor signals in his electrical work because the contact between the “finger” and the wafer is a “point contact”. He has asked you to find an optimum angle at which the “finger” should approach the wafer so that the contact will be more like an “area contact” without causing permanent deformation of the finger. The electrical contact “finger” is sufficiently stiff and assume that it can be modeled as a cantilever beam. Note that the angle of the support relative to the wafer dictates the angle at which the finger approaches the wafer. Can you find such an “optimum” angle? If not, show rigorously that it is not possible to make this into an “area contact” as the electrical engineer claims.
I considered the geometry of the beams
Taking the Length of the si wafter (diameter)=300mm
Thickness=1mm
Length of the CU finger=10mm
Thickness of the Cu finger=0.3mm
Slope (θ)=∫ (M/EI)dx
Deflection(v)=∫∫(M/EI)dx*dx
I(si wafer)=(300*1^3)/12=25mm
I(cu finger)=(10*0.3^3)/12=0.0225mm
E (si wafer)=163Gpa
E(cu finger)=117Gpa
Iam really confused how to solve this problem,there is no load mentioned.
Theoretically slope= (-P*L^2)/(2*E*I) for an end point load cantilever beam,can anyone suggest the right approach to this problem?
So, the angle at which the beam begins to deform permanently is when the maximum stress in the beam approaches the yield strength of copper. That is dependent on this equation:
[itex]\sigma=\frac{My_{max}}{I}[/itex]
[itex]y_{max}=thickness/2[/itex]
[itex]\sigma=[/itex]stress in beam, should be set equal to yielding strength of copper
So, once you've found M from the above equation, plug that into your integral for the slope angle, θ
[itex]Slope(\theta)=\int\frac{M}{EI}dx[/itex]
Related to Moment Deflection Relationship Problem
1. What is the moment deflection relationship problem?
The moment deflection relationship problem is a structural engineering concept that refers to the behavior of a beam or structural element when subjected to an external force or moment. It involves determining the relationship between the applied moment and the resulting deflection of the beam.
2. How is the moment deflection relationship determined?
The moment deflection relationship can be determined through mathematical equations and calculations, as well as experimental testing. The exact method varies depending on the type of beam and the specific loading conditions.
3. What factors affect the moment deflection relationship?
The moment deflection relationship is affected by several factors, including the material properties of the beam (such as strength and stiffness), the shape and size of the beam, the type of loading (such as point load or distributed load), and the support conditions (such as fixed or pinned).
4. Why is the moment deflection relationship important in structural engineering?
The moment deflection relationship is important because it helps engineers design and analyze structures to ensure they can withstand the expected loads and maintain their stability. It also allows for the optimization of structural elements to minimize deflections, which can affect the overall performance and safety of a structure.
5. How does the moment deflection relationship affect the design of a structure?
The moment deflection relationship is essential in the design of structures because it helps determine the appropriate size and shape of structural elements to ensure they can withstand the expected loads without excessive deflection. It also allows for the identification of potential weak points in a structure that may need reinforcement or additional support.
18K
