MHB Moment generating function question
The discussion revolves around finding the moment generating function (MGF) of the sum SN of independent and identically distributed (i.i.d.) random variables X1, X2, ..., XN, where N is an independent non-negative integer-valued random variable. Participants express uncertainty about the distribution of the X variables and how to derive the MGF without this information. A proposed formula for the MGF is presented, assuming a normal distribution for the X variables, leading to the expression m_{SN}(t) = ∑ p_n e^{(n/2)σ²t²}. Clarifications are sought regarding the derivation of this formula and the implications of the distributions involved. The conversation emphasizes the importance of understanding the relationship between the random variables and their distributions in calculating the MGF.
oyth94
Let X1,X2,…,Xn be independent random variables that all have the same distribution, let N be an independent non-negative integer valued random variable, and let SN:=X1+X2+⋯+XN. Find an expression for the moment generating function of SN
so all i know is that it is i.i.d but i am not sure what distribution it is in order to find the moment generating function. how do i solve this question?
Re: moment generating function question
I'm not sure to have correctly understood... is N, the number of random variables, a random variable itself?...
Kind regards
$\chi$ $\sigma$
Let suppose that we know the quantity...
$\displaystyle p_{n}= P \{N=n\}\ (1)$
... and each continuous r.v. is $\displaystyle \mathcal {N} (0,\sigma)$, then is...
$\displaystyle m_{S_{N}} (t) = \sum_{n=1}^{\infty} p_{n}\ e^{\frac{n}{2}\ \sigma^{2}\ t^{2}}\ (2)$
Kind regards
$\chi$ $\sigma$
Kind regards
$\chi$ $\sigma$
I'm not sure how you arrived at this answer..can you please explain?
If I understood correctly, the $X_{i}, i=1,2,...,N$ are continuous r.v. with the same p.d.f. f(x) [which is not specified...] and N is a discrete r.v. with discrete p.d.f. $p_{n} = P \{N=n\}, n=1,2,...\ $. Setting $S = X_{1} + X_{2} + ... + X_{N}$, the r.v. S has p.d.f. ...
$\displaystyle f_{N} (x) = f(x) * f(x) * ... * f(x),\text{N times}\ (1)$
... and the moment generating function is...$\displaystyle m_{S} (t) = E \{e^{S\ t}\} = \sum_{n=1}^{\infty} p_{n}\ \int_{- \infty}^{+ \infty} e^{x\ t} f_{n} (x)\ dx\ (2)$Kind regards $\chi$ $\sigma$
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
