MHB Moment of Force F & P: Calculation & Solution
The discussion centers on calculating the moment of forces F and P about points A, B, C, and D, with specific values of 200 kg and 165 kg, respectively. The numbers 5, 4, and 3 refer to the dimensions of a right triangle formed by the vector representing the force, where 4 is the horizontal distance, 3 is the vertical distance, and 5 is the hypotenuse. This triangle helps in determining the slope and direction of the force vector. The calculation assumes clockwise moments as positive. Understanding these values is crucial for accurate moment calculations.
bergausstein
I just don't know where did the numbers 5,4, and 3 came from. please explain.
I'am asked to do this
assuming clockwise moments as positive, compute the moment of force F = 200 kg and force P = 165 kg about points A, B, C, and D.
the solution picture is here
Mathematics news on Phys.org
That particular force is represented by a vector that goes 4 grid squares to the right and 3 grid squares up.
The triangle identifies its slope.
The hypotenuse of that triangle is 5.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
