Moment of inertia and the geometric center
The discussion revolves around calculating the moments of inertia for a composite structure made of profiled steel I and C sections. The calculations involve determining the geometric center and total area, with specific values provided for each section. Participants highlight the importance of using symbolic names for dimensions to clarify calculations and avoid confusion. There are concerns about the accuracy of height measurements used in the calculations, as well as the need to compute the mass center of the composite structure accurately. Overall, the thread emphasizes the complexity of the moment of inertia calculations and the necessity for clear communication of the underlying equations.
masterchiefo
The profiled steel I above is topped by a " profiled C ".
Determine the moments of inertia of the structure composed by the axes
central x and y through its geometric center C.
Picture representing the problem:
Profiled C and I information:
Section
All numbers are coming from the table for this first part.
Profiled I: A= 14400mm2 /y=0 /x=0 /y*A=0 /x*A=0
Profiled C: A= 2897mm2 /y=16.10 /x=0 /y*A=46641.7 /x*A=0
Total A = 17297mm2
/Y∑A = ∑/yA /Y*(17297) = 46641.7 /Y =26.9652mm
For the Profiled I :
Ix' = /Ix +A/Y2 =554*106 + 14400*26.96522
= 564.47*106
For the Profiled C:
Height of profiled I = 460, half = 230
Now to get height of mass center of I to mass center of section C I do 230-(22.8-16.10)
16.10 is the distance from mass center of section C to the top of the section, but I need mass center to bottom of that section so 22.8-16.10.
Ix' = /Ix +A*height2 = 0.949*106 +(2897)*(230-(22.8-16.10))2
=145.402*106
Total
145.402*106 + 564.47*106
= 709.872*106
It's hard having to reverse engineer your logic from the numbers. It would be a lot easier to check if you were to create symbolic names for all the dimensions and post your working in terms of those.
Total A = 17297mm2
/Y∑A = ∑/yA /Y*(17297) = 466417 /Y =26.9652mm
You seem to be taking the height of the mass centre of the C section from where it contacts the I section as the sole basis for computing how far the addition of the C section displaces the vertical height of the mass centre from the centre of the I section. This ignores the distance from the mass centre of the I section to that point of contact. It ought to have given you a very small result, but you also seem to have lost a decimal point (46641.7, 466417).
Most numbers are coming from the table in the picture.
I will explain some that aren't in the table in the main post.
"This ignores the distance from the mass centre of the I section to that point of contact."
Sorry I don't understand that part. My numbers for the first part are all coming from the table.
edit: I have edited the thread with some explanation.
I don't care where they come from, I don't want to have to read them then trace back to find out what they represent.
Let's just say you have an I-beam height hI, width wI, cross-sectional area AI, etc., and a cap height hC, etc. Leave numbers out of it. Post an equation for your answer in terms of these unknowns. After that we can move on to plugging in numbers to get a numerical answer.
Sure, but I presume you are trying to compute the mass centre of the composite. Even if the C cap were a point mass, it would shift the mass centre because of its distance from the mass centre of the I beam.
Is this better ? Sorry if I made it confusing. I thank you very much for your time into helping me.
Section C:
Ix' = Inertia in X-X axis +Surface Area*height2
height: mass center of section C to mass center of section I
Section I:
height: mass center of section I to point C in the drawing.
That's not exactly what I was after.
In the tables you posted, there are 7 numbers that describe the I section. Assign a unique variable name to each.
Likewise, there are 8 numbers for the C section. Assign unique variable names to each of those.
Then show your working and results entirely in terms of those variable names. Don't substitute their numerical values until the absolute final step of the calculation.
(Now, it is a bit confusing that the C section's description has x and y swapped from the way the C section is employed in the composite. I don't mind too much how you handle that in assigning the names, as long as it is clear.)
Anyway, to respond to your post,
masterchiefo said:
Section C:
I assume this is with X in the C section's co-ordinates, so it's vertical in the composite.
That should give the MoI of the C section within the composite about the mass centre of the I section.
But
(a) I don't see how you got 230-(22.8-16.10) for that height. The 230 is ok, if a little inaccurate, but where does the rest come from?
(b) You want the MoI about the mass centre of the composite.
masterchiefo said:
Section I:
Which co-ordinate system is this in? In the OP you have Inertia in X-X axis = 554*106, but don't explain how this was obtained. (This is the sort of thing that would be perfectly clea if you were to work symbolically.)
In my first response I challenged this calculation:
Please respond to that.
But
Hey man, to be honest I am not sure at all with anything I did on this problem, this is very new subject to me and very confusing at the moment, I will try to read more and figure out how moment of inertia work.
thanks again.
  • · Replies 42 ·
19K
