Moment of inertia and torque of a yoyo
In summary, Julien calculated the moment of inertia of the yoyo, derived the moment of inertia of a disk of mass M and radius r about its axis of symmetry, and calculated the torque when the yoyo is "falling". He found that the angular frequency ω when the string is half unrolled is ω=2πR/L.
JulienB
408
Hi everybody! I know that is a classical problem, but I haven't been able to find an answer to my questions in the other threads so here we go:
We have a yoyo made of 3 aluminium disks (density ρ). The two side disks have a radius R and thickness D, and the middle disk has a radius R0 and a thickness D0. The string has length l (see picture).
a) Calculate the moment of inertia of the yoyo. Derive then the moment of inertia of a disk of mass M and radius r about its axis of symmetry.
b) Calculate the torque when the yoyo is "falling". In which direction does it point?
c) What is the angular frequency ω when the string is half unrolled?
Moment of inertia, torque, tangential acceleration and so on.
a) My first issue attempting to solve this problem is that I am unsure whether the radius R0 should be considered when calculating the moment of inertia of the yoyo. I am confused, because the string is responsible for the rotation but yet the yoyo is rotating about its axis of symmetry. Therefore I would assume the moment of inertia of the yoyo is:
Iyoyo = 2⋅Ibig disk + Ismall disk
= 2⋅(ρπDR4) + ½ρπD0R04
= ρπ⋅(DR4 + ½⋅D0R04)
I quickly add the calculation for the moment of inertia of a disk:
Idisk = ρ∫ r2dV = ρDπr4/2 = ½ ⋅Mr2
Is that correct, or is there any need to use the parallel axis theorem?
b) Here it becomes complicated. I think the only force playing a role on the rotation is the tension force of the string, therefore:
Στ = I⋅α = F⋅R0 where α is of course the angular acceleration ⇒ α = aT/R0.
I also think aT = ay and Myoyo⋅g - I⋅α/R0 = Myoyo⋅g - I⋅ay/R02 = Myoyo⋅ay
ay = Myoyo⋅g / (Myoyo + I/R0)
But when I insert that in my torque equation, it gets crazy:
Στ = I⋅α = (I/r0)⋅(Myoyo⋅g / M + I/R0)
When I plug my moment of inertia in, nothing good comes out and it gets very messy. Have I made a mistake or should I also put up an equation of energy?Thank you very much in advance.EDIT: I just saw a similar problem on internet where the guy takes the point of contact of the string with the disk as the torque axis. Is that really allowed?? If so, would I have to use the parallel axis theorem because we don't take the center of the yoyo as axis of rotation anymore? Julien.
You seem to have forgotten the factor 1/2 in Ibig disk.
You can approach it in either of two ways. Use the MoI about mass centre and torque about mass centre (radius x tension); or use the parallel axis theorem to find the MoI about point of contact of the string and torque about that point (radius x mg). They should lead to the same answer. You just have to pick your axis and be consistent.
@haruspex I don't think I forgot the 1/2, because there are two big disks. No? I'll give the problem another try tomorrow and post again :)
Well, you forgot it here:
But I see you found it again here:
@haruspex My mistake I forgot it by copying my notes. Thank you for your attention :)
I gave it another go but still get a crazy result for the torque:
Why do you think it's crazy. I would not bother multiplying out the factors in the numerator. You have an error in the denominator going from the second line to the third line... a factor of 2.
Likes JulienB
@haruspex Thank you for your answer. I'm doing the problem again, and I'm wondering: shouldn't I have taken aT = g (instead of the whole acceleration (m⋅g - T)/m) in my torque equation?
Julien.
Julien.
How are you defining aT? Certainly the sum of vertical forces is mg-T downwards.
Likes JulienB
@haruspex Nevermind I got it wrong. Sorry for that :)
Related to Moment of inertia and torque of a yoyo
1. What is moment of inertia?
Moment of inertia is a measure of an object's resistance to changes in its rotational motion. It is dependent on the mass and distribution of the object's mass relative to its axis of rotation.
2. How is moment of inertia different for a yoyo compared to other objects?
The moment of inertia for a yoyo is unique because it is constantly changing as the yoyo spins and the string unwinds. This is due to the shifting distribution of mass as the yoyo's radius changes.
3. What is torque and how does it relate to a yoyo?
Torque is a measure of the force that causes an object to rotate. In the case of a yoyo, the force of the string pulling on the axle creates a torque that causes the yoyo to spin.
4. How does the moment of inertia affect the performance of a yoyo?
The moment of inertia of a yoyo directly impacts how quickly it will spin and how long it will spin for. A lower moment of inertia means the yoyo will spin faster, while a higher moment of inertia will result in a slower spin.
5. Can the moment of inertia and torque of a yoyo be manipulated?
Yes, the moment of inertia and torque of a yoyo can be altered by changing the distribution of mass in the yoyo or by using a different string material that affects the amount of friction on the axle. This can result in different performance characteristics for the yoyo.
9K
