Moment of inertia by connecting two identical rods
In summary: This case being the question I posted to start the thread. Moment of inertia gives a general idea of the distribution of mass. Given by I = Mx^2/3, it tells you how much mass is needed to keep a object rotating about a particular axis.
judas_priest
174
Four T-shaped objects are constructed by connecting two identical rods of equal mass and equal length. Rank in order, from LARGEST to SMALLEST, the moments of inertia for rotation about the axis indicated by the dashed line.
For the first, I used parallel axis theorem for the rod length l away, and for the rod perpendicular to the axis, I took its MI as m*l^2/3. I'm pretty sure that's a wrong approach. I need someone to point out how to go about this.
You do not really need to compute the moments. You can use the general formula and compare them by reasoning whether terms in the formula will be larger or smaller.
Try this. Just look at the pictures. Which do you think has the largest moment of inertia, and which do you think has the smallest? Compare the two intermediate cases. Which do you think has the larger and which do you think has the smaller?
Chet
Chet
A has the largest and C the smallest? Only using intuition and a little physics. Please correct if I'm wrong.
In that case A=D. Correct?
Cases A and D is similar. The total moment in both case is the sum of the moment of the bar perpendicular to the axis of rotation, and of the moment of the bar parallel to the axis. The moment of the perp. bar is the same in both case; but is the moment of the par. bar the same? Observe its distance from the axis is not equal in the two cases.
How do I find the perpendicular Moment of inertia?
Well, any moment of inertia is "perpendicular" in the sense that you consider the distance from the axis of rotation, and the distance is perpendicular to the axis.
But what really meant was that there two bars, one in perpendicular and the other parallel to the axis of rotation, and they have certain moment about the axis.
Let me reframe my question -
How do I find the the moment of inertia of the rod perpendicular to the axis asked to find about
Like I said, you do not really need to find it in this problem. But if you want to anyway, you need to use the general formula for the moment of inertia.
How do I find the moment of inertias in this case? Which is greater than which?
I do not know what "this case" is.
Anyway, what is the definition of the moment of inertia?
This case being the question I posted to start the thread. Moment of inertia gives a general idea of the distribution of mass. Given by I = M*R^2
I have already suggested how you could handle this problem, with more details given in #6. I do not think you hear what I have been saying.
These are both correct. Now all you need to do is to decide between B and D. Note that the portion of the "T" perpendicular to the axis of B is the same as the portion of the "T" perpendicular to the axis of D. How do the portions of the T's parallel to the axes in this two figures compare in terms of their distances from the axis?
FAQ: Moment of inertia by connecting two identical rods
What is moment of inertia by connecting two identical rods?
Moment of inertia by connecting two identical rods is a physical property that measures the resistance of an object to changes in its rotational motion. It is the sum of the products of mass and the square of the distance from the axis of rotation for each particle in the object. Connecting two identical rods increases the moment of inertia as it increases the mass and the distance from the axis of rotation.
How is moment of inertia by connecting two identical rods calculated?
To calculate the moment of inertia by connecting two identical rods, the parallel axis theorem can be used. This involves adding the moment of inertia of each rod individually and then adding the additional moment of inertia due to the distance between the two rods. The formula for moment of inertia is I = Σmr², where m is the mass and r is the distance from the axis of rotation.
How does connecting two identical rods affect the moment of inertia?
Connecting two identical rods increases the moment of inertia by increasing the mass and the distance from the axis of rotation. This is because the added mass and distance contribute to the overall resistance to changes in rotational motion. The moment of inertia of the two connected rods will be greater than the moment of inertia of each individual rod.
What factors affect the moment of inertia by connecting two identical rods?
The main factors that affect the moment of inertia by connecting two identical rods are the mass and the distance between the two rods. Increasing either of these factors will increase the moment of inertia. Additionally, the shape and distribution of mass along the rods can also impact the moment of inertia.
What are some real-life applications of moment of inertia by connecting two identical rods?
Moment of inertia by connecting two identical rods has various real-life applications, such as in the design of rotating machinery, such as flywheels and turbines. It is also important in sports equipment, such as golf clubs and tennis rackets, as it affects the ease of rotation and control. In the automotive industry, moment of inertia is considered when designing the components of a vehicle's engine and transmission systems.
