vetgirl1990
- 85
- 3
Find the moment of inertia of these composite objects.
I've attached two different composite objects; each rod has length L and mass M.
I = Icm + MD2
Long thin rod with rotation axis through centre: Icm = 1/12ML2
Long thin rod with rotation axis through end: Icm = 1/3ML2
(a) For the image on the left:
I first found the total inertia of the objects: Icm total = 1/12ML2
Then applied the Parallel Axis Theorem, because the composite object is rotating parallel to the actual axis of rotation: I = 5/12ML2 + 2MD2 (where D is the distance between the object's centre of mass and axis of rotation).
Feedback on this?
(b) For the image on the right:
Since one of the rods are going through the axis of rotation, I don't think I need to apply the Parallel Axis Theorem... So I just found the total inertia for both objects based on where their axis of rotation is.
I = ICM axis through centre + ICM axis through end
= 1/12ML2 + 1/3M(L/2)2
= 1/12ML2 + 1/3ML2/4
= 1/6 ML2
