"Moment of Inertia" in Virial Theorem
In summary, the moment of inertia is typically defined with respect to a rotational axis and involves calculating the perpendicular distances of particles from that axis. However, for non-rigid collections of particles, the concept of a moment of inertia may not apply. In addition, the virial theorem, which is often used for non-rigid collections, may use a quantity that resembles a moment of inertia but is not actually the same. The most general definition of the moment of inertia can be found at the provided link.
throneoo
126
Moment of inertia is supposed to be defined with respect to a rotational axis such that for a system of point masses, I=∑miri2 where ri 's are the perpendicular distances of the particles from the axis.
However, in some derivations of the virial theorem (like the one on wiki), the so-called "scalar" moment of inertia, the ri 's are taken to be the magnitude of the position vectors of those particles with respect to the origin without reference to any axis. My question is, does it still have the same physical significance as its ordinary counterpart? This quantity at most indicates the overall separation of the particles from the origin
Astronomy news on Phys.org
Actually, that's not the general definition of a moment of inertia. That only applies for rigid bodies that have enough symmetry to be rotating around a fixed axis, more general rigid bodies have only a moment of inertia tensor and can have their axis of rotation wobble. Even when we choose axes that make the moment of inertia tensor diagonal, it only means that there will be different moments of inertia of the form you mention around each of those axes (and rotation around the axis with the middle-sized moment of inertia will not be stable, and will wobble). The most general definition of the moment of inertia of a rigid body can be found here: http://farside.ph.utexas.edu/teaching/336k/Newtonhtml/node64.html
The virial theorem is usually used on collections of particles that are not rigid, and the appearance of a quantity that in some superficial ways resembles a moment of inertia is just a coincidence. It's not the moment of inertia.
after readig ur link i realized talking about the moment of inertia of a non rigid collection of particles does not make much sense lol.
thanks.
FAQ: "Moment of Inertia" in Virial Theorem
What is Moment of Inertia?
Moment of inertia is a measure of an object's resistance to changes in its rotational motion. It is calculated by multiplying the mass of an object by the square of its distance from the axis of rotation.
How is Moment of Inertia related to the Virial Theorem?
In the Virial Theorem, the moment of inertia is used to calculate the kinetic energy of a system in terms of its potential energy. This relationship is important in understanding the stability and equilibrium of a system.
How is Moment of Inertia different from Mass?
Moment of inertia and mass are related but different concepts. While mass measures the amount of matter in an object, moment of inertia measures its resistance to changes in rotational motion.
How is Moment of Inertia calculated?
The moment of inertia of a point mass is calculated by multiplying the mass of the point by the square of its distance from the axis of rotation. For extended objects, the moment of inertia is calculated by integrating the mass distribution over the object's volume or area.
What is the significance of Moment of Inertia in physics?
Moment of inertia plays a crucial role in the study of rotational motion and the stability of physical systems. It is used in many important equations, including the Virial Theorem, and is essential in understanding the behavior of objects such as wheels, gears, and planets.
