Moment of inertia of a cube along the diagonal.
In summary: This means you can do this problem by picking three axes through the centroid, say the x, y, and z in the usual orientation. The moment of inertia about each of these axes will be the same, but you need to be careful because the x and y axes are rotated 45 degrees relative to the sides of the cube, so the moments of inertia about these are not the same as the cube's moment of inertia about its own axes. In summary, The moment of inertia of a cube rotating along its diagonal axis can be calculated by first finding the moments of inertia about three axes passing through the centroid and aligned with the edges of the cube, and then rotating them to the diagonal axis using the relevant equations. Alternatively, the moment of
carllacan
274
Calculate the moment of inertia of a cube which rotates along an axis along its diagonal.
Moment of inertia definition: [itex]I = \int \rho (\vec{r}) \vec{r} ^2 dV[/itex]
Angular velocity vector; [itex]\vec{\omega}=\omega (\frac{1}{\sqrt{3}}, \frac{1}{\sqrt{3}}, \frac{1}{\sqrt{3}})[/itex]
My biggest problem is on finding the position vector for the volume element. My try at it goes like this:
[itex]
\vec{r} = \vec{p}- \vec{p}·\vec{\omega} \frac{\vec{\omega}}{\omega}
[/itex]
Where [itex]\vec{p}[/itex] is the point of interest. With this we calculate the difference between the point's vector and a vector with the direction of [itex]\vec{\omega}[/itex] and magnitude equal to that of the component of [itex]\vec{p}[/itex] along [itex]\vec{\omega}[/itex]. This should be the shortest vector from the axis of rotation to the point. Am I right?
I think, however, that there is an easier way to solve this. Isn't there any shortcut similar to the Steiner Theorem, only for rotates axes?
Thank you.
The moment of inertia values for a body form a tensor. Instead of trying to calculate the moment of inertia directly using the diagonal as an axis, calculate the moments using an axis aligned with the edges of the cube passing through the centroid and rotate them to the diagonal.
This discussion is relevant:
http://www.eng.auburn.edu/~marghitu/MECH2110/staticsC4.pdf
See Eq. 4.8 on page 5
The section you refer to talks about translation of axis. Isn't this problem more about a rotation of axes? Anyway, thanks for the link. I used the results on section 4.2 for a general axis and I obtained this:
[itex] I = \frac{\rho}{\sqrt{3}}(-\frac{1}{2} ab^2c^2+\frac{1}{2} a^2bc^2-\frac{1}{2} a^2b^2c + \frac{2}{3}b^3)[/itex]
Does it make any sense? It doesn't for me. Why is the horizontal dimension given appear on its own? Shouldn't it be symmetrical?
Eq. 4.8 (and Sec. 4.2) come before Sec. 4.3, Translation of Coordinate Axes.
As to the validity of your calculations, I don't know. Why don't you show the full work up, starting with your calculation of the inertia tensor before rotation?
Ah, right, I misread you answer.
My calculations look like this:
[itex]
I = \int dV| \vec{u} x \vec{r}|^2 = \int dV \left | \begin{array}{ccc}
\vec{i} & \vec{j} & \vec{k} \\
\frac{1}{\sqrt{3}} & \frac{1}{\sqrt{3}} & \frac{1}{\sqrt{3}} \\
x & y & z \\ \end{array} \right | = \int dV \frac{1}{\sqrt{3}} (z - y, -z + x, y - x)^2 =
[/itex]
[itex]
\int dV \frac{1}{\sqrt{3}} (z^2 -2zy + y^2 -z^2 + 2zx -x^2 + y^2 - 2yx + x^2) = \frac{1}{\sqrt{3}} \int dV ( -2zy + y^2 + 2zx + y^2 - 2yx) =[/itex]
[itex] \frac{1}{\sqrt{3}} ( -\frac{ab^2c^2}{2} + \frac{a^2bc^2}{2} - -\frac{a^2b^2c}{2}+ \frac{2}{3}b^3 )
[/itex]
It's not clear what the length of the edge of the cube is.
You also have 2 i's in your integral determinant.
If the edge length of the cube is say 'a', then the inertia tensor of the cube of uniform density about its centroidal axes will have entries only on the main diagonal (the products of inertia are identically zero because of symmetry). These values on the main diagonal will be
I[itex]_{xx}[/itex] = I[itex]_{yy}[/itex] = I[itex]_{zz}[/itex] = [itex]\frac{m}{12}[/itex]*(a[itex]^{2}[/itex]+a[itex]^{2}[/itex]) = [itex]\frac{m}{6}[/itex]*a[itex]^{2}[/itex]
m = ρ a[itex]^{3}[/itex], where ρ is the density
and off diagonal
I[itex]_{xy}[/itex] = I[itex]_{yz}[/itex] = I[itex]_{xz}[/itex] = 0
You can apply Eq. 4.8 to this tensor without evaluating the integral.
Something went wrong in post #5, because the last term in your answer has the different dimensions (length^3) compared with the others (length^5).
And if this is a cube, why are there three different dimensions a b and c?
The really neat way to do this is not Eq 4.8, but look further down at sections 4.4 and 4.5. For a cube, the "ellipsoid of inertia" is not a general ellipsoid. The three axes are the sane length, so it is a sphere. That means the inertia is the same about any line through the centroid. The inertia tensor about any set of axes through the centroid is a diagonal matrix with the three equal terms on the diagonal.
Related to Moment of inertia of a cube along the diagonal.
1. What is the moment of inertia of a cube along the diagonal?
The moment of inertia of a cube along the diagonal is a measure of its resistance to rotational motion around an axis passing through its center and parallel to one of its diagonals.
2. How is the moment of inertia of a cube along the diagonal calculated?
The moment of inertia of a cube along the diagonal can be calculated using the formula I = (1/6) * m * (a^2 + b^2), where m is the mass of the cube and a and b are the lengths of its sides.
3. What factors affect the moment of inertia of a cube along the diagonal?
The moment of inertia of a cube along the diagonal is affected by its mass and the lengths of its sides. The larger the mass and longer the sides, the greater the moment of inertia.
4. Why is the moment of inertia of a cube along the diagonal important?
The moment of inertia of a cube along the diagonal is important in understanding the rotational motion of objects around an axis. It is also used in engineering and physics to analyze the stability and balance of structures.
5. How does the moment of inertia of a cube along the diagonal compare to other shapes?
The moment of inertia of a cube along the diagonal is greater than that of a cube along one of its sides, but smaller than that of a sphere or cylinder with the same mass and dimensions. This is because the mass of a cube is more spread out along its diagonal compared to a sphere or cylinder.
