Moment of inertia of a hollow cylinder derivation
To derive the moment of inertia of a hollow cylinder, the volume element dV is expressed as (2πR)(dR)(h), representing a thin ring rather than the entire cylinder. This approach helps in integrating over the radius to find the total volume of the hollow cylinder. Understanding this small volume element is crucial for correctly setting up the integration for the moment of inertia calculation. The formula for the moment of inertia is confirmed as I=1/2M(R_1^2+R_2^2) when the axis of rotation is through the center along the axis of symmetry. Properly visualizing the geometry of the thin ring aids in grasping the rationale behind the volume element used in the derivation.
Carpetfizz
Show that a hollow cylinder of radius R_1, outer radius R_2, and mass M, is I=1/2M(R_1^2+R_2^2) if the rotation axis is through the center along the axis of symmetry.
$$dm = \rho dV$$
$$dV = (2 \pi R)(dR)(h)$$
I was mainly confused about why dV is expressed as (2piR)(dR)(h) since the Volume of a cylinder is 2pir^2h. I know that the variable of integration is R so there has to be a dR in there somewhere, but I'm having trouble understanding the rationale.
$$dm = \rho dV$$
##dV## is not a cylinder. It is a small piece of a cylinder. Can you see what shape it is?
It's a thin ring, sorry.
It has length ##h##, so it is effectively a thin hollow cylinder. Using this ##dV## would be one way to show that the volume of a cylinder is ##\pi R^2 h##. You could also use this to get the volume of your hollow cylinder.
You could try that as a preliminary exercise before you do the MoI calculation. I find that can be a useful test that you've set up your integration properly, as you know the answer in advance.
  • · Replies 40 ·
