jcd2012
- 5
A uniform thin rod with mass 4.59 kilograms pivots about an axis through its center and perpendicular to its length. Two small bodies with a mass of 0.543 kilograms, are attached to the ends of the rod. What is the length of the rod such that the moment of inertia of the three-body system with respect to the described axis is 0.941 kg·m^2?
Length of Rod = L (unknown)
For the rod, MoI = 1/12ML
For the two small masses, MoI of each is: MoI = MR^2
MoI-rod + MoI-mass + MoI-mass = ƩI
Moment of Inertia of Rod: 1/12(4.59 kg )L
Moment of Inertia of Mass: (0.543 kg) * (L/2)^2
For moment of inertia of small mass, I picked the radius from the axis of rotation to be L/2 since the axis of rotation is at the rod's center and perpendicular to its length. I thought the radius from that point to the small mass would be L/2.
So the setup is: 1/12(4.59)L + (0.543)(L/2)^2 + (0.543)(L/2)^2 = 0.941
When I solve for L, I get L = 1.28609 m, which is apparently incorrect. I do not know where I could have screwed up on this problem.
