Moment of inertia of a triangle
The discussion centers on the absence of moment of inertia values for triangles along the y-axis in most textbooks. It highlights that while triangles typically lack specified values, any shape theoretically has a second moment of inertia about any axis. Participants suggest that the y-axis is arbitrary and request illustrations for clarity. The conversation emphasizes the need for better representation of triangular shapes in educational materials. Understanding moment of inertia for various axes is crucial for applications in engineering and physics.
jayborre
Guys,
In most books, why is it that triangles doesn't have moment inertia along the y-axis as well as the centroidal moment of inertia along the y-axis.
Thank you and GOD bless
Regards,
Jay
y-axis is kind of arbitrary, can you provide an illustration or anything? In theory, any shape has a Second Moment of Inertia about any axis.
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
