Moment of inertia of combined cylinders
In summary, the author explains how to calculate the inertia of a composite body composed of three cylinders by using the Parallel Axis Theorem. The attachment also includes a formula to calculate the moment of inertia of a single cylinder.
IBAStudent
Hi, I've attached a word document with my problem since I've used the Mathtype program (sorry, I didn't quite know how to use the tools on this forum), hope you don't mind :)
  • Moment of inertia of combined cylinders.docx
There are ways of calculating the inertia of composite bodies which do not involve evaluating the integrals contained in your attachment.
See: http://www.eng.auburn.edu/users/marghitu/MECH2110/C_4.pdf
By calculating the moment of inertia of each cylinder, one then uses the Parallel Axis Theorem to calculate the moment of inertia of the composite body composed of three cylinders. The attachment also contains a formula to calculate the moment of inertia of a single cylinder given the radius and length, so no integrals are required at all for calculating the result.
I didn't quite understand that, sorry. I thought the parallel axis theorem only was for changing the axis of objects? All my three objects are attached at the same axis, so I didn't quite get how I use the theorem. Also, the link you sent didn't contain anything about combined objects?
Thanks for your answer, anyways, I'm just a grasping this concept completely.
Your description of the three cylinders is ambiguous. You say all three cylinders are attached to the same axis and that you have two smaller cylinders attached to the sides of a big cylinder.
A couple of questions:
1. Are all three cylinders running parallel to one another like this:
a.)
Or are they like this:
b.)
If configuration a.), you will need the Parallel Axis Theorem.
Section 4.3 in the attachment shows how to apply the PAT for composite bodies. The procedure composite bodies is analogous to that for combining the inertias of composite areas.
2. Does the density of your cylinders vary as a function of the radius of the cylinder, or do you have three constant density cylinders, with each cylinder having a different value for its density?
Hi, sorry for the ambiguous description, the cylinders are glued together like in your b.) illustration, in other words the flat sides are glued together.
The three cylinders are actually just pipes short pipes about 20 and 8 cm in diameter and 2 mm thick, so the density of each cylinder is not constant since the mass is distributed near the rolling surface of the cylinders. So yes, in a way, the mass density is a function of the cylinder's radius, where the density is mostly 0, while it's constant at a distance equal to the radius of the cylinder, since it's like a hoop.
If these cylinders are pipes, do they contain anything (water, air, etc.?)
For the most part, in calculating the inertia of hollow objects, the inertia of the contents of the cavity is not computed unless there is significant mass present.
No, there's just air inside, so the mass of the cavity can be neglected.
On the last page of my attachment, you will find a formula for calculating the moment of inertia of a hollow cylinder about its centroid. Since the cylinders are of different sizes, you can use the parallel axis theorem to calculate the moment of inertia of the composite body after you determine the location of the centroid of the composite configuration.
FAQ: Moment of inertia of combined cylinders
What is the formula for calculating the moment of inertia of combined cylinders?
The formula for calculating the moment of inertia of combined cylinders is I = ∑(m_i * r_i^2), where I is the moment of inertia, m_i is the mass of each individual cylinder, and r_i is the radius of each individual cylinder.
How do you determine the axis of rotation for combined cylinders?
The axis of rotation for combined cylinders can be determined by finding the point where the combined cylinders are balanced and do not rotate when a force is applied. This point will be the axis of rotation for the cylinders.
Can the moment of inertia of combined cylinders be negative?
No, the moment of inertia of combined cylinders cannot be negative as it is a measure of an object's resistance to changes in its rotational motion. Negative values do not make physical sense in this context.
How does the moment of inertia change when cylinders of different sizes are combined?
The moment of inertia increases when cylinders of different sizes are combined, as the combined mass and distribution of mass from the different cylinders will have a greater impact on the overall rotational motion of the object.
Are there any real-life applications of calculating the moment of inertia of combined cylinders?
Yes, calculating the moment of inertia of combined cylinders is useful in many real-life situations, such as designing rotating machinery, analyzing the stability of structures, and predicting the behavior of vehicles during turns or collisions.
