Moments - How are they actually calculated?
  • Thread starter Thread starter 012anonymousx
    Moments
Moments are calculated using the perpendicular component of the force relative to the axis of rotation, multiplied by the distance from the pivot point. The parallel component of the force does not contribute to the moment since it has a zero perpendicular distance. Mathematically, the moment is expressed as the cross product of the position vector and the force vector. The magnitude of the moment can be calculated using the formula l = rf*sin(θ), where θ is the angle between the position and force vectors. Understanding this distinction is crucial for accurate moment calculations.
012anonymousx
Moments -- How are they actually calculated?
Hello, I have a question.
Is the moment calculated:
Force times the distance or
Force's perpendicular component (to axis) times the distance.
For example, let's say I have a stick.
Pulling on it is not moment.
So if I push at the stick to an angle, the way I calculate the force that the other side is applying is by taking the perpendicular component of my Fa and multiplying it by the distance.
Is that correct?
Yes, when you are calculating moments, you would use the perpendicular component. The parallel component will not produce any moment as the perpendicular distance is zero.
Likes 1 person
Mathematically, a moment is ##\vec{l} = \vec{r} \times \vec{f}##. The magnitude comes out as ##l = rf\sin\theta##, where ##\theta## is the angle between the position vector and the force vector. This is equivalent to saying that it is the perpendicular component of the force.
Likes 1 person
Thank you!
Topic about reference frames, center of rotation, postion of origin etc Comoving ref. frame is frame that is attached to moving object, does that mean, in that frame translation and rotation of object is zero, because origin and axes(x,y,z) are fixed to object? Is it same if you place origin of frame at object center of mass or at object tail? What type of comoving frame exist? What is lab frame? If we talk about center of rotation do we always need to specified from what frame we observe?
  • · Replies 49 ·
  • · Replies 138 ·
  • · Replies 17 ·
  • · Replies 49 ·
  • · Replies 66 ·
