Moments of Inertia for Composite Area
In summary, the homework statement states that the moment of inertia of the cross sectional area of the T beam with respect to the x' axis passing through the centroid of the cross section is 27.0(106) mm. The attempt at a solution provides an equation to calculate the moment of inertia of the cross sectional area of the T beam with respect to the x' axis passing through the centroid of the cross section.
jdawg
367
Determine the moment of inertia of the cross sectional area of the T beam with respect to the x' axis passing through the centroid of the cross section.(I'm attaching a diagram)
Hi! I'm having a little trouble with this problem. I've already calculated the centroid with respect to y to be 60 mm.
Ix'=Ix+A(dy)2
Ix'=(1/12)(150)(303)+(150)(30)[(150)(30)(60-15)]
What I don't understand is how they are calculating dy! Could someone please explain to me what they are doing?
  • h.pdf
I forgot to mention that it is problem F10-8!
Ix'=Ix+A(dy)2
It's not clear what they are doing.
The centroid of the cross section is indeed 60 mm from the base of the flange (the wide piece at the bottom).
Ix for the web (the vertical piece) = (1/12)(150)(303), but the rest of the calculation makes no sense to me.
The standard method of finding the MOI of a composite body is to calculate the MOIs for the individual pieces about a common reference, in this case the bottom of the flange, for example), and then use the parallel axis theorem to correct the MOI for the entire section back to the centroid.
Evaluating Ix as shown in the OP does not give the correct value of the MOI about the centroid of the cross section.
I'm sorry, I know that wasn't very clear. That was only finding the moment of inertia for one of the segments.
This is the answer they have in the back of my book: Ix=[(1/12)(150)(303) + (105)(30)(60-15)2 + [(1/12)(30)(1503) + (30)(150)(105-60)2 = 27.0(106) mm4
How did they know to use the bottom of the flange as the common reference? I don't understand the (dy)2 part of the equation at all.
You can use any point as your point of reference.
For the parallel axis theorem: I = MOI about centroid + Area*distance to reference.
So for the 30 mm x 150 mm section, then centroid of the entire shape is at 60 mm from the bottom flange.
About its own centroid Ic = 1/12 (150)(30)3 and its area is (150)(30).
The distance of the centroid of the 30 mm x 150 mm section to the centroid of the entire shape is 60 mm - 15 mm (this is the dy).
Thus the MOI of this section is 1/12 (150)(30)3 + (150)(30)(60-15)2
Likes jdawg and Chestermiller
You can use whatever point as a reference for the calculation. Using the bottom of the flange is just as arbitrary as using the top of the web. It doesn't make a difference to the final result.
As far as the answer to the problem is concerned:
This is the answer they have in the back of my book: Ix=[(1/12)(150)(303) + (150)(30)(60-15)2 + [(1/12)(30)(1503) + (30)(150)(105-60)2 = 27.0(106) mm4
The number 150 is in red because you (or someone) apparently transposed some digits in the dimension of the flange).
Knowing that the centroid is 60 mm above the bottom of the flange, the MOI of the flange about this reference is the sum of the MOI of the flange about the its centroid, which is (1/12)(150)(303), plus the transfer value to shift the MOI from the centroid of the flange to the centroid of the entire section, or (150)(30)(60-15)2. The second part of this expression calculates the MOI of the web about its centroid and then shifts it to the centroid of the entire section. Adding these two calculations together gives the MOI of the T about the centroid of the T.
Likes jdawg
Thanks so much for the help, I think I get it now! :)
FAQ: Moments of Inertia for Composite Area
What is a moment of inertia for composite area?
A moment of inertia for composite area is a measure of an object's resistance to changes in its rotational motion. It takes into account the distribution of mass and shape of an object and is used to calculate the object's angular acceleration.
How is a moment of inertia for composite area calculated?
A moment of inertia for composite area is calculated by dividing the object into smaller, simpler shapes and using the parallel axis theorem to calculate the moment of inertia for each shape. These individual moments of inertia are then added together to get the total moment of inertia for the composite area.
What is the difference between a moment of inertia and a moment of inertia for composite area?
A moment of inertia is a property of a single object, while a moment of inertia for composite area takes into account the combined effect of multiple objects with different shapes and orientations.
Why is a moment of inertia for composite area important in engineering?
A moment of inertia for composite area is important in engineering because it helps engineers understand the behavior of a complex object under rotational motion. It is used in the design and analysis of structures, machinery, and other mechanical systems.
How can a moment of inertia for composite area be used in real-world applications?
A moment of inertia for composite area can be used in various real-world applications, such as designing and analyzing the stability of buildings, bridges, and other structures. It is also used in the design of rotating machinery, such as turbines and propellers, to ensure their safe and efficient operation.
