MHB Moments of Inertia & Radius of Gyration
The discussion focuses on calculating moments of inertia about the x-axis, y-axis, and the origin, as well as finding the radius of gyration for a given density function, ρ = ky. Participants confirm that ky is indeed the density function and agree on the limits of integration being y = 0 to b and x = 0 to a. The importance of setting up double integrals for these calculations is emphasized, with a reminder that the choice of axis affects the moment of inertia. The conversation also touches on communication clarity, with participants encouraged to seek clarification when needed. Overall, the thread highlights the mathematical process involved in solving for moments of inertia and the collaborative nature of learning in this context.
harpazo
Find the moments of inertia about the x-axis, y-axis and the origin. Also, find the radius of gyration about the x-axis and y-axis.
y = 0, y = b, x = 0, x = a
Rho = ky
1. Is ky the density function?
2. Do I integrate over dxdy or dydx?
3. Are the limits of integration y = 0, y = b, x = 0, and x = a?
4. For Rho = ky, is k constant?
Rho = ky
Yep!
I don't think it's going to matter, because the region of integration is rectangular.
Yep!
I would assume so.
So you'd want to start with
$$I=\int r^2 \, dm,$$
and then understand that $\rho = \dfrac{dm}{dA}$, or $\rho \, dA = dm$. Can you continue?
Incidentally, I'm a fan of using $\lambda$ for linear mass density, $\sigma$ for area mass density, and $\rho$ for volume mass density. This problem is squarely in the area mass density, so I would normally write $\sigma \, dA = dm$.
Ackbach said:
Yep!
Yep!
I would assume so.
Sorry, where did r^2 come from?
That's from the definition of the moment of inertia. If you consider a small chunk of mass $dm$, then $r$ is the perpendicular distance from that chunk of mass to the axis of rotation. So you can see that the moment of inertia is highly dependent on your choice of the axis of rotation.
Can you set up the double integrals? I can then solve the problem on my own.
So,
$$I=\int r^2 \, dm = \iint r^2 \, \rho \, dA = \iint \, r^2 \rho \, dy \, dx.$$
You need to figure out the limits for $x$ and $y$, plug in the expression for $\rho$, and finally you need to figure out what the radius is from the area chunk $dx\,dy$ to the specified axis of rotation, plug that into $r^2$, and then you're on your way.
Forget it.
Harpazo said:
Forget it.
Excuse me? Are you unsure of some of the steps that I've outlined? If so, please let me know, and I'll help you through them.
Absolutely unsure of your reply. Try writing in a student-friendly matter.
The best thing here is to point out which parts of the previous replies are unclear, and to ask for clarification.
That's not a fair statement to make, is it? If something isn't clear, then please and by all means...ask for clarification, but don't accuse the person trying to help of writing in an unfriendly manner, unless you can point to a statement made that is clearly unfriendly. I don't see anything like that in this thread.
For what it's worth, Adrian (Ackbach) has well over a decade of experience with online math sites providing help as well as working professionally as an educator for many years. He firmly believes that the student should do the heavy lifting, but is willing to explain further if something he posted is not clear to the student.
I didn't like the "Excuse me?" way in which he started his reply.
Well, let's try to be objective and examine the context in which it was said. He posted judicious help (i.e., guidance), to which you replied "Forget it." To me, this seemed to be dismissive, implying the help he provided was inadequate or lacking in some way. He provided a suggestion for continuing, and when you did not follow those suggestions, he perhaps found it confounding that you were not willing to follow through there.
I can assure you Adrian was not trying to be rude...he was likely just wondering why you would dismiss his suggestions rather than make an attempt to follow them. (Wondering)
Setting up the integrals is the whole point of these type of problems - it's more than $70\%$ of the work. Often cranking through the integrals themselves is routine. That's why I haven't posted any more of the solution. What about what I've written so far is unclear to you? I'd be happy to clarify anything that's not clear.
Considering that this question goes back to May 9th of this year, we should move on now. I am in the chapter dealing with cylindrical and spherical triple integrals. If I get stuck somewhere in the chapter, I will return to this forum with my questions. Agree? I do not want to argue about my question posted more than one month ago. I thank everyone here for their math help and guidance.
Sure! No problem.
  • · Replies 20 ·
  • · Replies 24 ·
