Momentum and collisions problem
In summary, the conversation discusses two objects of different masses sliding without friction down the sides of a hemispherical bowl and colliding at the bottom. The question is posed about the maximum height the objects will reach if the collision is completely inelastic. Two solutions are suggested, one using conservation of momentum and the other using the idea of center of mass. The answer is determined to be 7.5cm above the bottom of the bowl.
jayman16
Two objects of masses 2.0 kg and 6.0kg slide without friction
down the sides of a hemispherical bowl. Both start with zero velocity at
the lip, which is 12 cm above the bottom. The objects collide at the bottom of the bowl. Just
before the collision, they are moving at right angles to each other. To what maximum height
above the bowl will the objects move if the collision is completely inelastic? You may treat the
objects as small particles.
Solution 1:
Using mgy and 1/2mv^2 find out the velocity of both masses just before they collide at the bottom of the bowl. Then using conservation of momentum, determine the final velocity of the 8kg mass(completely inelastic) and then by using mgy and 1/2mv^2 again find out the distance the 8k mass travels up the bowl. (answer is 7.5cm, this 7.5 cm is the vertical distance from the bottom of the bowl, not the arc length over which the mass moves)
I was wondering if it would be possible to do this problem by using the idea of center of mass of the 2 masses just before they collide and consider it as a 8kg mass with a resultant velocity and calculate the answer ignoring the collision altogether since the collision represents internal forces and there is no external force on the cm besides mg.
figured it out thanks
Related to Momentum and collisions problem
1. What is momentum and why is it important in collisions?
Momentum is a measure of an object's motion. It is defined as the product of an object's mass and velocity. In collisions, momentum is important because it determines the force that is exerted on the objects involved, and therefore affects the outcome of the collision.
2. How is momentum conserved in a collision?
In a closed system, the total momentum before a collision is equal to the total momentum after the collision. This is known as the law of conservation of momentum. This means that the total mass and velocity of the objects involved in the collision will remain constant.
3. How do you calculate the momentum of an object?
The momentum of an object can be calculated by multiplying its mass by its velocity. The formula for momentum is p = mv, where p is momentum, m is mass, and v is velocity. The SI unit for momentum is kilogram-meter per second (kg-m/s).
4. What is the difference between elastic and inelastic collisions?
In an elastic collision, both momentum and kinetic energy are conserved. This means that the objects involved will bounce off each other and retain their original shapes and velocities. In an inelastic collision, only momentum is conserved. This means that the objects involved will stick together and some kinetic energy will be lost in the form of heat or sound.
5. How does the mass and velocity of objects affect the outcome of a collision?
The mass and velocity of objects have a direct impact on the momentum of the objects involved in a collision. The larger the mass and velocity of an object, the greater its momentum and the more force it will exert on other objects in a collision. This can result in more damage or changes to the objects involved in the collision.
9K
