Momentum and Impulse Cannonball
  • Thread starter Thread starter hallowon
    Impulse Momentum
A 200 kg shot is fired horizontally from a 20,000 kg cannon at 250 m/s, prompting a discussion on calculating the steady force needed to stop the cannon's recoil in 2 seconds and the distance it will recoil. Using conservation of momentum, the recoil velocity of the cannon is determined to be 2.5 m/s backwards, leading to a required force of 25,000 N forwards to halt the recoil. The conversation emphasizes the need for equations linking acceleration, initial velocity, and distance to find the recoil distance. Participants confirm the calculations and express relief about the accuracy of the results. The discussion concludes with a positive acknowledgment of the problem-solving process.
hallowon
35
A 2.00X10^2 kg(200kg) shot is discarded horizontally from a cannon of mass 2.0x10^4kg(20000), with a speed of 250 m/s relative to ground.
Find steady force which, acting on the cannon, will stop its recoil in 2.0s
and
How far will cannon recoil
j=fnetxt
using conservation of momemntum
p= p'
MsVs+McVc = MsVs' + McVc'
0 = MsVs' + McVc'
-msvs'= McVc
and found Vc to be 2.5 m/s backwards,
and using j=fnet t
McVc' = fnet t
fnet =( 20000)(2.5) /2
fnet = 25 000N backwards
so i said steady force was 25 000 N forward needed to stop recoil in 2 seconds
Which I am doubtful whether it is right, and do not know how i could find the distance of cannon recoil.
From my calculations, you got the force required to stop the cannon in two seconds correct! Since the problem specifies that the force is steady, you know that the cannon undergoes constant acceleration. Now, do you know any equations that link the acceleration, initial velocity, and distance travelled?
Edit: You also need to know an equation that relates force and acceleration, but that one's easy. :rolleyes:
woot found the new reply button -_-
so iguess 2ad = vf^2 -vi^2 i guess huh
thanks for your help :D i was getting worried for nothing :D
Looks good to me!
Thread 'Minimum mass of a block'
Here we know that if block B is going to move up or just be at the verge of moving up will act downwards and maximum static friction will act downwards Now what im confused by is how will we know " how quickly" block B reaches its maximum static friction value without any numbers, the suggested solution says that when block A is at its maximum extension, then block B will start to move up but with a certain set of values couldn't block A reach...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
