Momentum and Inertial Reference Frame
In summary: And the mother has non-zero momentum in the same frame of reference. But zero momentum in a frame of reference where she is motionless.In summary, two 20-kg girls at a roller rink collide stomach-to-stomach and grab onto each other, falling to the floor. In the Earth reference frame, they are initially moving at 2.7 m/s each. In the reference frame of a mother who starts skating with one of the girls and continues on after the collision, the initial momentum of the first girl is 0 and the initial momentum of the second girl is 108 kg*m/s. After the collision, in the reference frame described in part B, the momentum of each girl is 54 kg*m/s.
jjkim623
At the roller rink, two 20-kg girls accelerate toward each other until they are each moving at 2.7 m/sin the Earth reference frame. They then collide stomach-to-stomach, grab on to each other, and fall to the floor.
A. Calculate the magnitudes of the momentum of each girl before the collision in the reference frame of a mother who started skating with one of the girls and then continued on after the collision without changing speed. Denote the momentum of the girl that moves with the mother as p1 and the momentum of other girl as p2.
B. Calculate the magnitudes of the momentum of each girl after the collision in the reference frame described in part B.
p=mv
A. If the girl moving with the mom is using the mom as a reference frame, then |p1|=0 since her velocity is 0 relative to the mom. The part I'm stuck on is how to figure out |p2| given an inertial frame of reference that's moving. Despite using the mom as the inertial reference frame versus the Earth, wouldn't conservation of momentum imply that relative to the mom...
p1initial + p2initial = p1final + p2final
and if
pfinal= 20*(-2.7) + 20*-2.7= -108 kg*m/s2
then
pinitial= 20*0 + 20v2,f= -108 kg*m/s2
so
|p2initial| = |20v2,f| = |-108|= 108 kg*m/s2
B. If both the girls have a velocity of zero (relative to the Earth), but the mom is moving away to the right, then that would mean that relative to the mom, the girls would be moving to the left. Therefore, the momentum of the each girl relative to the mom would be p= m(-v)= (20)(-2.7)= -54, but because the question is asking for magnitude, the answer is +54.
Is my thinking correct?
jjkim623 said:
wouldn't conservation of momentum imply that for girl 2...
pinitial (relative to the Earth)=pinitial (relative to the mom)
[Total] momentum [in a closed system] is a conserved quantity. That is, it does not matter when you look, the total momentum is always the same.
[Total] momentum [in a closed system] is not an invariant quantity. It does matter what frame of reference you use when you look. The total momentum can change depending on your choice of reference system.
As you note, the girl clearly has zero momentum in a frame of reference where she is motionless. And non-zero momentum otherwise.
Related to Momentum and Inertial Reference Frame
1. What is momentum?
Momentum is a measure of an object's motion, calculated by multiplying its mass by its velocity. It is a vector quantity, meaning it has both magnitude and direction.
2. How is momentum conserved?
The law of conservation of momentum states that the total momentum of a closed system remains constant, regardless of any internal or external forces acting on it. This means that in a collision or interaction between two objects, the total momentum before and after the event will be the same.
3. What is an inertial reference frame?
An inertial reference frame is a frame of reference in which Newton's first law of motion holds true. This means that an object at rest will remain at rest, and an object in motion will continue to move at a constant velocity, unless acted upon by an external force.
4. How does an inertial reference frame relate to momentum?
In an inertial reference frame, the conservation of momentum holds true. This means that if the total momentum of a system is conserved, the reference frame is considered inertial. This is because in an inertial reference frame, there are no external forces acting on the system to change its momentum.
5. Can momentum be transferred between inertial and non-inertial reference frames?
No, momentum can only be transferred between objects within the same inertial reference frame. In a non-inertial reference frame, such as a rotating frame, there are fictitious forces present that can change an object's momentum, making it not truly conserved. Therefore, momentum cannot be transferred between inertial and non-inertial reference frames.
