Calculating Change in Kinetic Energy for a Collision on a Frictionless Air Table
In a collision on a frictionless air table, puck A (0.250 kg) moves towards stationary puck B (0.360 kg) and after the collision, puck A moves at 0.125 m/s left while puck B moves at 0.655 m/s right. The initial velocity of puck A was calculated to be 0.818 m/s. The change in total kinetic energy was computed as ΔK = KE(initial) - KE(final), resulting in a value of 0.00487 J. There is confusion regarding the sign of puck A's velocity and whether significant digits affect the calculations. The calculations for kinetic energy may need reevaluation for accuracy.
Elissa
On a frictionless, horizontal air table, puck A (with mass 0.250 kg ) is moving toward puck B (with mass 0.360 kg ), that is initially at rest. After the collision, puck A has a velocity of 0.125 m/s to the left, and puck B has velocity 0.655 m/s to the right.
I already solved for the puck's initial velocity, which is 0.818m/s. Now I have to find the change in the total kinetic energy of the system that occurs during the collision.
KE=(1/2)mv^2
KE(initial)=(1/2)(0.250kg)(0.818m/s)^2=0.0805J
KE(final)=(1/2)(0.250kg)(0.125m/s)^2+(1/2)(0.360kg)(0.655m/s)^2=0.07917
ΔK=0.0805J-0.07917J=0.00487J.
I tried this both negative and positive, but both are wrong. I don't know what I did wrong.
Please show your work.
mv=m1v1+m2v2
v=(-(0.125m/s)(0.250kg)+(0.655m/s)(0.360kg))/0.250kg=0.818m/s. This is definitely right because I already submitted the answer and got it correct.
Should the velocity of Puck A be negative when solving for kinetic energy?
Is whatever program you are feeding the answers into sensitive to the number of significant digits?
This is not numerically correct.
  • · Replies 22 ·
