Momentum and percent kinetic energy loss
In summary, a 1200 kg car traveling at 20 m/s collides with a stationary 1400 kg car and the two cars lock together. After the collision, 80% of the initial kinetic energy is converted to heat and sound, resulting in a final velocity of 6.1 m/s. The collision is considered completely inelastic because the bodies stick together due to inelastic forces. The maximum energy that can be lost without violating the Law of Conservation of momentum is when the dissipative forces/inelastic deformations are present, and the momentum is conserved.
physicsstudent30192
1.) A 1200 kg car traveling at 20 m/s collides with a stationary 1400 kg car. The two cars lock together. Determine the speed of the vehicles immediately after the collision if 80% of the initial kinetic energy is converted to heat and sound during the collision
2.) Must all kinetic energy be lost in a collision for the collision to be considered completely inelastic? Explain
Ek = 1/2mv^2
For both of these questions I have the answers to them in the book but I can't seem to arrive at/understand the solution.
1.) 80% loss so..
4/5 Ekintial = Ekfinal
(4/5) * (1/2)(1200 kg)(20 m/s)2 + 0 = (1/2)(1200 kg + 1400 kg)(v2)
v^2 = 147.6923 m/s
v = 12.15 m/s
The answer should be 6.1 m/s according to my textbook though.
2. ) "No. As much as possible must be lost without violating the Law of Conversation of momentum" is the answer in the book.
Does this mean the maximum energy lost while the momentum of the system is equal for both the initial and final?
also, how do I know if an equation is completely inelastic rather than just inelastic?
physicsstudent30192 said:
1.) 80% loss so..
check ,why using lost energy for calculation?
Likes physicsstudent30192
if the dissipative forces /inelastic deformations are there then one can say the collision is inelastic-the proof is non equality of energy before and energy after the event. however momentum is conserved.
completely inelastic means bodies joined/stick together during collision due to inelastic forces.
Oh wow, I should read over the questions better...changed the 4/5 to 1/5 and it worked. Thanks drvrm for both answers.
Related to Momentum and percent kinetic energy loss
1. What is momentum and percent kinetic energy loss?
Momentum is a measure of an object's motion, calculated by multiplying its mass and velocity. Percent kinetic energy loss is the amount of energy lost during a collision or interaction between objects.
2. How is momentum and percent kinetic energy loss related?
Momentum and percent kinetic energy loss are related because they are both affected by collisions or interactions between objects. When two objects collide, momentum is conserved but there is often a loss of kinetic energy. The amount of kinetic energy lost can be calculated as a percentage of the initial kinetic energy of the system.
3. What factors affect the amount of momentum and percent kinetic energy loss in a collision?
The mass and velocity of the objects involved are the main factors that affect the amount of momentum and percent kinetic energy loss in a collision. Generally, the greater the mass and velocity of the objects, the greater the momentum and kinetic energy loss will be.
4. How is the law of conservation of momentum related to momentum and percent kinetic energy loss?
The law of conservation of momentum states that the total momentum of a system remains constant in the absence of external forces. In a collision, the total momentum of the system before and after the collision must be equal. This means that any loss of kinetic energy during the collision will be reflected in an increase in momentum.
5. What are some real-life examples of momentum and percent kinetic energy loss?
Some common examples of momentum and percent kinetic energy loss include car crashes, sports collisions, and pendulum swings. In a car crash, the kinetic energy of the moving vehicle is transferred to other objects, such as the other car or the surrounding environment, resulting in a loss of kinetic energy. In sports collisions, the players involved may experience a loss of kinetic energy due to the impact of the collision. And in a pendulum swing, the pendulum will gradually lose kinetic energy due to friction and air resistance.
