Momentum Conservation => EXPLOSION
In summary, when a projectile of mass M moving in the +x direction with speed V explodes into two fragments, a lighter one with mass M/4 and a heavier one with mass 3M/4, the heavier fragment moves in the -y direction with speed V. Using the momentum equation, it can be determined that the speed of the lighter fragment is 5V. This is found by solving for the x and y components of the lighter mass' velocity and then taking the magnitude of the resulting vector.
TwinGemini14
34
A projectile of mass M is moving in the +x direction with speed V when it explodes into two fragments: a lighter one having mass M/4 and a heavier one having mass 3M/4. The heavier fragment moves in the -y direction with speed V.
What is the speed of the lighter fragment? (Assume there are no external forces acting on the system).
A) V
B) 2V
C) 3V
D) 4V
E) 5V
So the momentum after is equal to the momentum before.
So... mVbx = (1/4)mvx + (3/4)mVx
mVbx = (1/4)mvx + (0)
mVbx = (1/4)mvx => vx = 4Vb
So... mvby = (1/4)mvy + (3/4)mVy => vy = Vb
Thus... 4vb+vb = 5vb
The answer is E, correct? Can somebody please look over this and confirm whether this is right or wrong? I'm not too confident. Thanks guys!
The answer is correct but your work as best I can follow is not (Which is why I don't give multiple choice tests).
Write your momentum equation as a vector and then identify components. Then you will solve for x and y components of the lighter mass' velocity. Remember then that the speed is the magnitude of this vector so take the square root of the sum of the squares of the components.
Yes, your answer is correct. According to the principle of conservation of momentum, the total momentum before the explosion (in the +x direction) must be equal to the total momentum after the explosion (taking into account the velocities and masses of the fragments in both the x and y directions). By setting up and solving the equations as you did, you correctly determined that the speed of the lighter fragment (Vb) must be equal to 4 times the speed of the original projectile (V). Therefore, the correct answer is E) 5V. Good job!
FAQ: Momentum Conservation => EXPLOSION
What is momentum conservation?
Momentum conservation is a fundamental principle in physics that states the total momentum of a system remains constant before and after a collision or explosion. This means that in a closed system, the total momentum before the event is equal to the total momentum after the event.
How does momentum conservation apply to explosions?
In an explosion, there is a sudden release of energy causing objects to move away from each other. According to the principle of momentum conservation, the total momentum of all objects involved in the explosion must remain the same before and after the explosion. This means that the sum of the momenta of all objects after the explosion must equal the sum of their momenta before the explosion.
Why is momentum conservation important in explosions?
Momentum conservation is important in explosions because it helps us understand and predict the motion of objects involved in the explosion. By knowing the initial and final momenta of objects, we can determine the direction and speed of their movement after the explosion. This information is crucial for ensuring safety and preventing potential hazards in explosive events.
Are there any exceptions to the principle of momentum conservation in explosions?
In most cases, momentum conservation holds true in explosions. However, there are some exceptions such as when external forces act on the system, or if there is a significant loss of mass during the explosion. In these situations, the total momentum of the system may not remain constant.
How is momentum conserved in a perfectly elastic explosion?
In a perfectly elastic explosion, there is no loss of kinetic energy, and all objects involved rebound without any deformation. In this case, the total momentum of the system is conserved as the sum of the momenta of all objects before the explosion is equal to the sum of their momenta after the explosion.
