I Momentum conservation for EM-Field/matter interaction
The discussion revolves around a paradox in the Feynman Lectures regarding the unequal action and reaction of two orthogonally moving charges, with a focus on calculating electric and magnetic fields, field momentum, and the complexities of integration. The proposed plan involves deriving the fields for each charge, using superposition to find the total fields, and then calculating the Poynting vector to determine momentum density. Challenges arise from the complicated integration process, especially when considering the infinite E field at distance-0. There is also a debate about the nature of field momentum density and its non-additivity, raising questions about the physical interpretation of these quantities. Ultimately, the discussion highlights the intricacies of electromagnetic theory and the relationship between field and particle momentum.
euphoricrhino
Hello,
I'm reading Feynman Lectures Vol II, and saw this "paradox" in section 26-2 (Figure 26-6), where two orthogonally moving charges can be shown to have unequal action and reactions. Later in Chapter 27, the explanation was given briefly citing field momentum.
I tried to prove this rigorously, but couldn't do so, below is my plan:
1. calculate the E and B field for each particle using formula for uniform-velocity charges and obtain E1,B1, E2, B2 as function of (x, y, z, t)
2. For any point in space, using superposition of fields, we can get E=E1+E2, and B=B1+B2
3. Obtain the Poynting vector ExB, thus the momentum density vector g as a function of (x, y, z, t)
4. Integrate g(x, y, z, t) over the whole space to get the total field momentum p at time t.
5. take the time derivative of p, and verify that this equals the difference between the action and reaction of the two charges.
The integration step is very complicated. I even simplified so one particle is taken to be at rest and the other particle moves straight to the first one. In this simplified case, the integration can be infinity since that the E field at distance-0 is infinity.
Is my plan at least reasonable (i.e., it's just a hard integration)? Another observation is that although E or B fields are additive from two charges, the momentum vector from two charges' fields is definitely not additive, am I understanding it correctly?
Thanks for any pointers.
In full generality it's helpful to consider a charge density ##\rho(\mathbf{r},t)##. In the case of two particles you can of course specialise this to ##\rho(\mathbf{r},t) = q_1\delta(\mathbf{r} - \mathbf{r}_1(t)) + q_2\delta(\mathbf{r} - \mathbf{r}_2(t))##. The Lorentz force per unit volume ##f_i = \rho E_i + \rho \epsilon_{ijk} v_j B_k## is related to the divergence ##\partial_j \sigma_{ij}## of the Maxwell stress tensor by the equation ## f_i = \partial_j \sigma_{ij} - \frac{1}{c^2} \partial_t S_i## (derivable from Maxwell's equations & the Lorentz force law). If you integrate this over some domain ##V## and invoke Gauss' theorem, you end up with\begin{align*}
-\frac{d}{dt} \int_V \frac{1}{c^2} S_i dV &= F_i - \int_{\partial V} \sigma_{ij} n_j dS \\
-\dot{p}_i^{\mathrm{field}} &= \dot{p}_i^{\mathrm{particles}} - \int_{\partial V} \sigma_{ij} n_j dS
\end{align*}and one identifies the rate of decrease of field momentum ##p_i^{\mathrm{field}} = \frac{1}{c^2} S_i ## with the rate of increase of the momentum ##p_i^{\mathrm{particles}}## of the charge inside ##V## and the momentum flux ##- \int_{\partial V} \sigma_{ij} n_j dS ## out of through the boundary.
Likes euphoricrhino, vanhees71 and dRic2
Thanks so much, this is very clear. In fact, FLP has dropped the hint when talking about momentum density without giving the derivation. I was able to derive the exact form based on your hint.
I guess my plan would have worked but the integration is too complex to evaluate, and the fact I was planning to integrate over the whole space should account for the momentum flux term in your post above (which should evaluate to zero at infinity).
There is also this question of "how real" is the quantity ##\mathbf{S}/c^2## as momentum density. They are just algebraic terms being interpreted as field momentum density to make equations work. It's plausible to rearrange the terms to get another equivalent equation which can be interpreted differently. If we treat ##\mathbf{S}/c^2## as momentum density, this would mean that the momenta of the two fields cannot be additive point-wise, which seems counter intuitive.
euphoricrhino said:
There is also this question of "how real" is the quantity S/c2 as momentum density. They are just algebraic terms being interpreted as field momentum density to make equations work.
Well, if you want to calculate the mechanical pressure on a surface due to the EM radiation, then S (its time average...) it's a pretty tangible thing... (https://en.wikipedia.org/wiki/Radiation_pressure)
Likes euphoricrhino
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
