Momentum Conservation: How to Reconcile a Negative Value?
The discussion centers on reconciling a negative value in momentum conservation calculations. The initial momentum is zero, and after firing, the equation results in a negative mass, indicating an error in direction assignment. Participants emphasize that momentum and velocity are vector quantities, and one must account for direction when calculating. A negative result signifies that the actual direction of the momentum is opposite to the initially assumed direction. The conversation highlights the importance of vector representation in mechanics problems to avoid confusion.
Shaye
A canon fires a cannonball of mass 55kg at 35ms^-1. The cannon recoils at 2.5 ms^-1.
What is the mass of the cannon?
p=mv
Maybe a silly question but on the above question using the conservation of momentum:
momentum before firing (0) = momentum after firing (55*35)+(M*2.5)
If I re-range the above it's M = -(55*35)/2.5 = -770kg. I can I reconcile that minus sign (basically get rid of it)?
Thanks
The momentum and velocity are vector quantities. The velocities are in opposite directions so one of them is negative.
It wasn't the question that was silly: it was having the cannon recoil in the same direction as the cannonball!
  • Haha
  • Skeptical
Likes Vanadium 50, kuruman, berkeman and 2 others
With these kinds of mechanics problems, making a vector drawing is really useful for keeping track of your signs ... also remember units.
Thanks everyone! A DOH! moment for me. Keeping track of the vectors is very useful
Likes Mayhem and PeroK
Actually the question is not silly in my opinion, yes there is a way to reconcile the negative sign without fudging the answer and I think @Shaye will profit from seeing how.
In mechanics problems, one often assigns a direction to an unknown vector and a symbol to its magnitude, goes through the calculations and if the magnitude turns out negative, then the actual direction is opposite to the initially assigned direction. The same method is famously used in circuit analysis when one assigns a direction to the current in a given loop, goes through the calculations and, if said current turns out negative, it actually flows in the opposite direction.
Here we have exactly the same principle at work. @Shaye chose the recoil momentum to be in the same direction as the cannonball, the magnitude of the momentum came out negative after the calculation, therefore ##\dots##
Likes berkeman and Shaye
  • · Replies 17 ·
