fab123
A 0,15kg frame, when suspended from a coil spring, stretches the spring 0,070m. A 0,200kg lump of putty is dropped from rest onto the frame from a height of 30,0cm. Find the Maximum distance the frame moves downward from its initial position.
I tried to solve the problem several times now but i can't seem to get the right answer, so i looked into the solution guide and there they use Conservation of momentum to the collision of the putty and the frame, however that is what gets me confused. I may be wrong but this is how i understood Conservation of momentum: Momentum of a system of particles is conserved if the net external forces Equal zero such that the total momentum of the system is constant. If that is the case, one can use that the change in momentum over any given period of time is Equal to zero. Now back to the problem:
Since the motion is happening along the y-axis there are external forces due to weight which (at least as I can tell) don't cancel out by other forces. Hence the external net force is not zero such that momentum is not conserved.
Now assuming that the solution in the solution guide is correct i have to misunderstood something which I think might be the part about the external forces not cancelling out each other.
I found the spring constant k by using the initial displacement of the spring due to the frame. Since the frame is in equilibrium one can solve kx-mg=0 for the spring konstant k since all the other variables are given. Then one can use, for example, constant Acceleration Equations to find the speed of the putty when it hits the frame. Also, one can later use Conservation of kinetic energy (ignoring air ressistance) since the total work done is the sum of potential gravitational and potential elastic energy.
PS:
I have found a post on this website about the same problem however addressing a different aspect of the problem.
