Momentum conserved but Kinetic Energy not conserved?
In summary, momentum is conserved in collisions even when kinetic energy is not. This is because momentum considers the change in velocity, while kinetic energy only considers the change in speed. In cases where only momentum is conserved, there are multiple solutions for the values of velocity and kinetic energy.
shangriphysics
32
I know that momentum is conserved when no "net" external forces such as Friction, Gravity, and air resistnace normal force; However, during inelastic collisions it says kinetic energy is not conserved because of external forces as well.
1. Are the external forces different for mechanical energy and conservation of momentum?
2. During inelastic collisions, KE is not conserved, therefore the velocity's will have values to make KEi not equal to KEf, How does momentum stay conserved if velocity is different for KineticInitial and Kineticfinal?
Maybe the momentum takes into account the velocity change from mechanical energy and also has different external forces and therefore momentum stays conserved despite mechanical energy not being conserved...
In inelastic collisions, work will be done deforming the objects. This will cause the sums of the initial KEs and final KEs to be different. Another way of writing KE is p^2/2m, and from that you can see that if the sums of the KEs are different, so will be the momenta.
does that help?
Look at the definitions of KE and momentum. Calculate some examples.
The sum of all forces acting on a system is equal to the sum of the external forces as the internal forces cancel each other. But the total energy of the system changes by the work of the external forces and also by the work of the internal ones.
Think of two people A an B, on ice, pushing each other. If the force from the ice is negligible, the forces are FBA and FAB , the force A pushes B and the force B pushes A. According to Newton's Third Law these forces are equal in magnitude and of opposite direction.
The total change of momentum in dT time is the net force times dt. The net force is zero, the net momentum does not change.
But the separate momenta of the persons do change. Assuming both persons in rest initially, B is pushed by A with force F acquires PA=mAVA momentum in dT time. A is pushed by B, with force -F and it gains PB= mBVB=-Fdt momentum. PB=-PA, but the kinetic energies are KEA=PA2/(2mA) and KEB= PB2/(2mB ) The kinetic energy of the whole system is KEA+KEB, different from the initial one.
ehild
Likes shangriphysics
When p and KE are both conserved there is only one possible solution. When only p is conserved And ##E_i > E_f## there are many possible solutions.
A change of KE without a change of momentum is not only possible but very frequent, because p = mv momentum varies linearly and KE quadratically. You can get the same product by a wide range of factors: 6 = 6*1, = 3*2, = 2*3, = 1*6, = 0.5*12, etc., different factors give same momentum
All these factors give same values for m*v, but as the figure for v must be squared, you get all different values between momentum and energy, therefore the same factors give momentum = 6, but KE =3, =6, =9, =18, =72, etc, same momentum corresponds to many different values of KE
Likes shangriphysics and alba
FAQ: Momentum conserved but Kinetic Energy not conserved?
1. Why is momentum conserved but kinetic energy not conserved?
According to the law of conservation of momentum, the total momentum of a closed system remains constant. This means that the total amount of momentum before an interaction or event must equal the total amount of momentum after. However, kinetic energy is not conserved because some of the initial kinetic energy can be converted into other forms of energy, such as heat or sound, during the interaction.
2. Can an object have momentum without having kinetic energy?
Yes, an object can have momentum without having kinetic energy. Momentum is a property of an object that depends on its mass and velocity, while kinetic energy is a measure of the energy an object possesses due to its motion. If an object is at rest, it has zero kinetic energy, but it can still have momentum if it has mass and is moving at a non-zero velocity.
3. What is an example of a situation where momentum is conserved but kinetic energy is not conserved?
A common example is an inelastic collision between two objects, where they stick together after colliding. In this scenario, the total momentum remains the same before and after the collision, but some of the initial kinetic energy is lost due to the objects becoming stuck together.
4. How is momentum conserved in an explosion if kinetic energy is not conserved?
In an explosion, the total momentum of the system remains the same, but the kinetic energy may not be conserved due to the release of potential energy. For example, in a rocket launch, the rocket has a large amount of potential energy stored in its fuel. As the fuel is burned and converted into kinetic energy, the rocket gains momentum, but some of the initial potential energy is lost.
5. Is it possible for both momentum and kinetic energy to be conserved?
Yes, it is possible for both momentum and kinetic energy to be conserved, but this is not always the case. In an elastic collision, where the objects bounce off each other without any energy loss, both momentum and kinetic energy are conserved. However, in most real-world scenarios, some energy will be lost due to friction or other factors, so both momentum and kinetic energy may not be conserved.
